2bits wrote:Lastly, this is my hinge setup being predrilled onto a 2x4. It is just two strips of aluminum with the hinge underneath with windshield sealant under that when I install it. I set a screw hole every 2 inches.
2bits wrote: I was thinking about yellow for turn signals or clear for back up lights (which I still will put in probably below the hatch) but I decided that I like the look of the dual Red lenses.
Russ B wrote:2bits wrote: I was thinking about yellow for turn signals or clear for back up lights (which I still will put in probably below the hatch) but I decided that I like the look of the dual Red lenses.
I've been pondering the same thing (as I lurk and slowly build a trailer in my head), but I came to the conclusion that one would have to do a custom wiring harness to get it to work. Seems like most standard 4/7-pin trailer plugs assume that you are using all red signal/tail/brake light combos. Not a problem if you only tow the teardrop, but kind of a pain if you want to tow a utility trailer or something else.
Just run them wires! haha...
So I guess it is OK to show my poxy jigsaw cut I needed to make so the hatch will sit in position...
"My belt sander is my friend" 5 min later looking downright smooth...
A little more light sanding and stain and we are good to go again.
It is HARD to resist the Git er Done feeling I have though! ! !
2bits wrote:Alrighty. Put this in the lessons learned category. All mistakes are OK... Once they are FIXED or HIDDEN.
Arne wrote:famous house builders saying: don't worry, the sheet rockers will cover it up.
2bits wrote:Well, I didn't get much done today, I got up at a decent time, I found a plywood shop open on Sat who had a 1/8" sheet of Baltic Birch and I went and picked it up. I then realized that I needed to be at a housewarming party right when I got home!
aggie79 wrote:Can you say which place was open on Saturday that had the 1/8" baltic birch? Since I'm still on probation at my new job (m-f, 8-5+), I can't really pick up anything during the week.
