Guesstimating Weight
Postby Creamcracker » Sat May 30, 2009 4:37 pm
Okay....so I put the bathroom scale under the tongue and it came up to 75lbs.....then I put the scale under one of the wheels and it went to 350lbs...I didn't put it under the other wheel since I figured that it would come out the same...so 350+ 350+75 gives me a total of 775lbs.....How close do you guys think that guesstimate may be to the actual weight? Any thoughts?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby ssrjim » Sat May 30, 2009 5:00 pm
I would think you would need three scales??? Seems you would be shifting the lbs a little.
93079
ssrjim
Postby Rock » Sat May 30, 2009 5:03 pm
Phil,
That's an excellent method - accurate to the accuracy of a bathroom scale.
The weight shift from lifting one wheel up a few inches is negligible.
Eric
Rock
Images: 48
Postby NCrado » Sat May 30, 2009 6:34 pm
Great.....now I've got to do it :lol:
I know, my vent's bass ackwards!
NCrado
Re: Guesstimating Weight
Postby starleen2 » Sat May 30, 2009 7:22 pm
Creamcracker wrote:Okay....so I put the bathroom scale under the tongue and it came up to 75lbs.....then I put the scale under one of the wheels and it went to 350lbs...I didn't put it under the other wheel since I figured that it would come out the same...so 350+ 350+75 gives me a total of 775lbs.....How close do you guys think that guesstimate may be to the actual weight? Any thoughts?
Philip
Might want to put it under the third wheel as well - I Made the same assumption, but when I weighed it I came up five pounds heavier! - I think it has something to do with the placement of the tongue jack on one side
starleen2
5th Teardrop Club
Postby Creamcracker » Sat May 30, 2009 7:44 pm
Philip
Mmmm! 5lbs? I think that's within a plus or minus error range that's acceptable.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Forrest747 » Sat May 30, 2009 11:58 pm
I do not know how accurate my weight was. I tried to weigh the frame to see how heavy and went to a couple of scales meant for 18 wheelers, they couldnt even weigh that little. Well i found a grainery and they let me use thier scale i did both the jeep and frame and then just the jeep alone. the difference came out to 460 pounds. I was off on my guess by 80 pounds or so.
Forrest747
Cowbell Donating Member
Images: 447
Postby kennyrayandersen » Sun May 31, 2009 6:50 am
in fact you did REAL well. Summation of Z forces must equal the total z force. Next concept summation of moments also equal zero :thumbsup: :thumbsup:
There will be a slight error, but it's noise -- 5 lbs out of 750 lb is less than 1% boo ya!
kennyrayandersen
Images: 38
