by Forrest747 » Sun May 31, 2009 12:05 am
The arc or bend in the axel, should be up. This is called the camber (Correct me if I am wrong guys). this will slightly put your wheels at an angle away from the body of the trailer.
With Charlie we forgot about this and we got lucky in welding the brackets that mate with the leaf springs. However, and there is always a however; if you want to move the axel the inside of the leaf spring instead of the outside, the camber or bow will be upside down.
To fix this you can cut off the old one or just go get two new brackets and put them on the other side of the axle, much easier and no real chance in weaking your axle. also if for what ever reason you want to move the axle to the outside of the leaf spring again, makes it alot easier.
