Tom,
Have you seen the CampInn way? I don't have any pics handy, but it is pretty simple and looks solid.
Kerry
arnereil wrote:Bruce, on your mechanical props, can the wind lift the hatch and let it drop? I read the blurb and it says it uses the star wheel system, where to close it, you lift it and drop it down to close. Can the wind do the same thing?
bdosborn wrote: I forget what the pin is called but it has a little ball bearing in the end so it can't come out of the hole. Push a button on the end of the pin and the ball bearing is retracted so you can remove the pin. Bruce
Endo wrote:The "pivoting hardware" at the top and the bottom of the props are door stops with the rubber end cut off. The rods are conduit. The black padding is pipe insulation. The padding keeps the props from beating up the counter and the inside of the hatch when traveling. The props are locked in place with cotter pins at the top. When not in use pull out the cotter pins and the props fold down and rest on the counter.
TomS wrote:I'm trying to visualize how this would work for me. I have a couple of questions:
Are you able to secure the support the hatch with one hand and insert the door stop into that conduit with the other hand?
Now, assuming you've got the first support in place. How do you insert the door stop into the second support without the first support poping loose? if you put put the cotter pin in the first side, how do you lift the hatch high enough to insert the door stop in the second support.
