by 48Rob » Fri Jun 05, 2009 6:09 am
I have a 5 gallon tank mounted under the floor to catch and hold greywater where needed, otherwise, i use a short section of hose to divert it a little ways away from the general campsite area to a tree or bush.
If it isn't an issue, it just soaks into the ground.
Water really isn't the problem (unless you make a mud hole for the next guy) food and soap are.
Soap if it isn't biodgradable, because of potential pollution, and food particles because of insects, animals, and smells.
If you carefully wipe the food particles off before washing pans, dishes, etc, there isn't much going on the ground, but when you consider the volume of campers that use a site, and dump things on the ground, it adds up.
However, people will be people...
I personally think empying wash water on the nearest trees or bushes helps, 'cause the last group of campers probably didn't want to walk to the restroom last night, and used them instead...
Then there are the dogs that think they have to go on every one of them...
Wash water dilutes all that concentrated "scent".
Rob
