The idea is simple. A 2'x4'x8' trailer with a hard top perfect for a bike rack. The box opens up, as does the back galley. This is all square sides and should be very easy to build.
mikeschn wrote:In the rain, the water will leak into the sides... you might want to fashion something to keep the rain out...
Elumia wrote:if the upper box goes into the lower box you have to worry about water running in that joint. The other way around, water can't get it.
Mark
