Mechanical Door (Hatch) props
Postby Geron » Tue Sep 20, 2005 11:23 am
Those of you who used the Mechanical Door (Hatch) props from Austin hdwe. What size (length) did you use??
Thanks,
Geron
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby norm perkiss » Tue Sep 20, 2005 7:12 pm
Geron,
I use this one. It is about 14+" closed and 27" when open.
http://www.austinhardware.com/product.a ... E96JHG9AMC
I proped the hatch up to the height that would clear my noggen and then located the prop on the side wall allowing for hatch ribs, cabinets, etc.
I mounted mine with the stock brackets. I have since talked to Uncle Denny, he modified the side wall bracket to fit almost flush. I will modify the bracket next time. It works perfect just not as slick an install as Denny.
norm perkiss
Images: 62
Postby Geron » Tue Sep 20, 2005 8:33 pm
norm perkiss wrote:Geron,
Thanks, very helpful.
Think that's the way I'll go.
Geron
Geron
Images: 173
Postby bdosborn » Wed Sep 21, 2005 11:15 pm
I think I got the same one 14"-27". At any rate, it was the biggest one they had. Don't know if you've skinned your hatch yet but I placed my props before I skinned mine. That way I could see where everything would lay out before I committed to screwing it in place.
Images: 806
