JayM wrote:They also require 12v for the control unit/thermostat, and can be pretty picky about low voltage, so allow for that when planning the electrical system if you plan to operate off-the-grid for any length of time.
atkryder wrote:I really like the idea of a free standing unit!!
Anyone have any thoughts on how to make an enclosure for one of these?
Great idea len!!
Great idea len!![/u]
eamarquardt wrote: ....The gases need to get up to the right temperature to separate so the cycle will function. they told me that the tube on the left side of the top coil should run about 155 to 160f.......There are lots of computer fans that run on 12 volts and draw as little as .25 amps which is practically nothing and you could go over 4 days at 100 duty cycle and not exhaust a typical 100 amp hour battery (that can really only deliver about 50 amp hours) even if two fans were required....
len19070 wrote:
Then just make a piece of metal (I used Galvanized sheet metal) to cover just the coils in the back. Connected to the side, across the back and then affixed to the other side. The metal should be about 1" away from the back of the coils.
Len
atkryder wrote:What do you mean by "Blind Application"? I like the the idea of a free standing unit but am not closed off to the idea of perminent installation if proper venting and accesability can be achieved.
