Roly Nelson wrote:Right now, with the doors and hatchlid in place, it still weighs less than 250 lbs. Whew!
Roly, ~~
demtears wrote:Thank's for the advice guy's! next stop....... home depot!
Square and level I think that's what you said! would you build from frame up, or if you could would you build it like asianflava did. It look's like he built his tear then installed it on the frame just wondering which would be the best way!Geron wrote:demtears wrote:Thank's for the advice guy's! next stop....... home depot!
An addendum:
As for the floor framing - not to worry too much -- you're going to bolt the whole thing to a metal chassis. Just make SURE it's SQUARE and LEVEL. This is absolutely essential or you'll be pulling your hair out later on.
Like I said: SQUARE and LEVEL. If your garage (building/ground) floor is not level, use adjustable jack stands. But GET IT SQUARE AND LEVEL. Did I say Square and Level??
g
