squeaka squeaka squeaka
Postby nikwax » Sun Jun 14, 2009 4:38 pm
I took my recently completed trailer out for its maiden drive, and with the windows down I could hear the suspension squeaking on potholes and bumps. The chassis is a HF 90154 (1450 lb) with Monroe shocks. Could the springs be making this sound, or is it more likely a bushing (spring or shock)?
Aside from strapping myself under the trailer and driving around, I've no idea how to diagnose this.
nikwax
Images: 30
Re: squeaka squeaka squeaka
Postby BrwBier » Sun Jun 14, 2009 8:05 pm
nikwax wrote:I took my recently completed trailer out for its maiden drive, and with the windows down I could hear the suspension squeaking on potholes and bumps. The chassis is a HF 90154 (1450 lb) with Monroe shocks. Could the springs be making this sound, or is it more likely a bushing (spring or shock)?
Why do you think creepers have wheels? ;) :lol:
Can you lay under it and have someone rock it? Or jack it up and use some spray grease on the springs, then go for a drive and see if the noise is gone.
Brwbier
BrwBier
Images: 100
Postby nikwax » Mon Jun 15, 2009 5:00 pm
sounds like a plan....the spray grease, not the creeper with road-legal casters :shock:
nikwax
Images: 30
Postby kennyrayandersen » Mon Jun 15, 2009 11:28 pm
there are only a few points that are rubbing. The bolts that hole the spring ends and the little swingy member (I'm sure that's the technical term!). Get those for sure plus anything els that looks like it moves -- it should shut up after that. :thumbsup:
kennyrayandersen
Images: 38
