Puzzled about roof spars - Do you round the edges?
Postby KDOG » Sun Jun 14, 2009 3:24 pm
I mean that in the curves of the profile, if you were to put the spars so they are flush with the edges, won't the corners of the spar stick up past the curve of the wall Do you sand/cut those corners off? I was thinking of using round dowel the same width as the other spars to eliminate this problem.
Also while I'm talking about spars, what dimensions would you recommend? 1x2?
FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
KDOG
Postby caseydog » Sun Jun 14, 2009 3:31 pm
I am using 1X2 poplar and did not round them.
CD
My build journal is HERE
caseydog
Images: 515
Postby mikeschn » Sun Jun 14, 2009 4:03 pm
I don't think people typically round them off.
Sure, if you were to compute it mathematically, you would only hit on the corners, but in practice, I think the glue fills up the voids where it's not completely flat.
Postby planovet » Sun Jun 14, 2009 4:54 pm
I used 2x4s that were ripped to fit. They have a very slight curve to the edges already. Worked fine for me.
ImageMark (& Cindi)
planovet
The Cat Man
Postby bbarry » Mon Jun 15, 2009 8:17 pm
The amount of curvature in your profile over the 3/4" width of the spar is so minimal as to be inconsequential. Don't worry about it!
Brad
Brad
Jack of all trades, master of none.
Kampster build thread
bbarry
Images: 159
Postby madjack » Mon Jun 15, 2009 8:32 pm
K, your thinking WAAAAAAAYYYYYYYY too much...a common problem as the Td "obsession" takes effect...place your spars, so the corners are flush with the wall edge and use a bead of urethane based adhesive(PL or Liquid nail or???)while applying the roof skins...it will span/fill a 3/8" gap...or as we do, lay the AL directly over the spars with no underlayment and use no adhesive at all.............
madjack 8)
Postby 2bits » Mon Jun 15, 2009 8:43 pm
Yeah, you are correct in your thinking, but it is so minimal it is not to be worried about.
Thomas
2bits
2bit Member
Postby Juneaudave » Mon Jun 15, 2009 8:44 pm
Watch it K...next these guys are going to be telling you to not worry about hollowing out the headliner side of the spars either :lol:
Juneaudave
Images: 380
Postby madjack » Mon Jun 15, 2009 9:00 pm
Juneaudave wrote:Watch it K...next these guys are going to be telling you to not worry about hollowing out the headliner side of the spars either :lol:
...errrrrrrrrr, do you mean to say that you don't :o :shock: :? .... :D :lol: ;) .......................... 8)
Postby planovet » Tue Jun 16, 2009 11:04 am
Dang, I knew I forgot something! :duh:
ImageMark (& Cindi)
planovet
The Cat Man
Postby RichAFix » Tue Jun 16, 2009 1:44 pm
Hmmmm, the weight savings of rounding the top and hollowing the bottom could be a half pound or so??? Everyone says "think light". I think you stumbled onto something here!
Listen to what I'm thinking, not what I'm saying.
RichAFix
Images: 10
Postby aggie79 » Tue Jun 16, 2009 10:12 pm
For those of you with too much time on your hands, how about making up some mini truss joists from plywood - about 1 1/2" deep? Lightweight, wide fastening flange, resistant to bowing or warping. What's not to like other than the PITA to make all of these. :shock:
:thumbsup: Gig'em, Tom
Postby doug hodder » Tue Jun 16, 2009 10:39 pm
I helium pack the ceiling, it's inert! Doug :thumbsup:
Postby Ron Dickey » Tue Jun 16, 2009 10:49 pm
to answer you question "NO" and in fact you later will forget what you did and will have to look bake at old shots to see what you did or where they are.
Worry more about how the galley will come out. If you put the wires in right and got them in place just move on.... it all comes together in the end.
173882......173887
Ron Dickey
Images: 787
Postby Dean in Eureka, CA » Tue Jun 16, 2009 11:14 pm
aggie79 wrote:How about making up some mini truss joists from plywood - about 1 1/2" deep?
All I can say is, "Thank God I didn't think of that" and just opted for 3/4" x 1 1/2" oak spars without giving it any further thought...
Dean in Eureka, CA
The Fogcrawler
Images: 69
