What is a "torsion box" I hear described in the discussion of frameless construction?
kennyrayandersen wrote:a 2000# axle is perhaps too robust and that's why you aren't seeing any deflection. If you build it pretty stout and start hitting 12oo lbs or something then it will ride better and you should see more vertical displacement.
The axle should be rated for the going-down-the-road weight.
madjack wrote:...that is one opinion...I spec a 1500# axle for a 1200#(loaded) trailer with torsion axles...this over spec, helps with the longevity of the axle and is especially true of a suspension which is under a constant load such as a TD...it is not as critical with a torsion axle as with a spring hung axle which should be ordered at 50% over desired weight carrying ability...IE, a 1200#(loaded) tear should have an 1800# rating for a spring hung axle.......
madjack![]()
p.s. loaded weight does not include the weight of the axle/wheel/tire combo for a spring hung axle or just wheel/tire combo for a torsion axle as that weight is "unsprung"........MJ
kennyrayandersen wrote:madjack wrote:...that is one opinion...I spec a 1500# axle for a 1200#(loaded) trailer with torsion axles...this over spec, helps with the longevity of the axle and is especially true of a suspension which is under a constant load such as a TD...it is not as critical with a torsion axle as with a spring hung axle which should be ordered at 50% over desired weight carrying ability...IE, a 1200#(loaded) tear should have an 1800# rating for a spring hung axle.......
madjack![]()
Maybe that's not so much over-spec-ed? Me thinks if you start using a 2000 pound rated axle on a 1000 pound trailer (full-up), the suspension isn't going to give so much and it kind of defeats the purpose of dmoothing out the ride and suckin' up the bumps.
