madjack wrote:...the AL is cut using the same template, the sides are cut with...holes for lights and fender bolts are located on this template...once cut, we take the AL side and put it in place...
aggie79 wrote:madjack wrote:...the AL is cut using the same template, the sides are cut with...holes for lights and fender bolts are located on this template...once cut, we take the AL side and put it in place...
Don't want to hijack the thread, but Madjack can you say how you cut your aluminum - with a router and template bit?
madjack wrote:aggie, first off, I make all the external cuts with an air shear(under 15 bucks from HF)...for this, you clamp the template, UNDER the sheet of AL...allow the jaw of the shear to ride along the template...you can cut a fairly fine line with the shear and not need to use the router on the edge...if you do need to router the outer edges, a straight bit with an end, guide bearing will be used(if needed) to clean up the edges...go ahead and cut out both sides......
...next, lay a sheet of styrofoam insul(cheap foil backed white stuff) on your work table...the insul will protect your workpiece and your table from the router bit...lay your AL cut out on the insul...lay your template on top of this, line 'em up and clamp 'em down...using a 3/8th template bushing and a 5/16 straight cut, plunge bit in your plunge router, cut out your door skin...since this is the same router/bit/template I cut the door out with, the AL skin should be the exact same as the door...you may need a speed control on your route(available at HF for around 15 bucks) if it(the router) is not variable speed...this will allow you to slow down the router to keep it from "slagging" it's way thru, instead of cutting...you will need to feed the router into your work VERY SLOWLY to avoid said slagging.....since I have located the holes for the running lights, fender bolts and shore power inlets in the template, I drill out the holes and cutout the shorepower opening with the plunge router...
...next, match up your doorskins with the door template and using the same techniques as above, cutout the window and latch openings...you should now have both wall skins and both door skins, with all appropriate openings, done and ready for installation........
madjack![]()
p.s. I built my templates with 1/2 MDF...makes for a heavy template but it holds up well and the 1/2" thickness give plenty of surface for the router bearing/bushing to ride upon..............MJ
shoeman wrote:I used a Kett electric shear. Borrowed from a buddy in the auto body business. Routers and aluminum make too many tiny flying pieces of shrapnel for my liking.
Standard old tin snips would work too but it'll be a major hand workout.
madjack wrote:Tom, don't know your experience level making/using templates and using router template bushings...these are kind of advanced techniques, so if not sure, check and recheck to make sure your openings in the template are sized properly...ASK IF YOU HAVE QUESTIONS!!!!!!!!!!!!
Users browsing this forum: Google [Bot] and 9 guests
