Aluminum skin overlap
Postby Southern Oregon Bob » Wed Sep 28, 2005 9:57 pm
I have an aluminum joint across the front top curve. Would you overlap the top to the front so it sheds rain water or the front over the top so it sheds water going down the road? I'm using the carpet glue, but should I use something else at the seam? :thinking:
Bob
Southern Oregon Bob
Postby SteveH » Wed Sep 28, 2005 10:00 pm
Bob,
If it were me, I'd overlap so the water would run off while it is seting. I would get some urethane sealer like is used on automotive windshields and seal it with that. About a 4" overlap would work.
These are my opinions and I'm shure others will have other methods for ya.
SteveH
SteveH
Images: 42
Postby madjack » Wed Sep 28, 2005 11:34 pm
....basically I agree with Steve, the carpet glue IMHO would not be sufficient, an automotive windsheild urethane or Sikaflex252 or something similar would be the trick along with a screw every couple of inches, also the lap should fall on a rib and the overlap should be at least 2+ inches
madjack 8)
Postby TonyCooper » Wed Sep 28, 2005 11:54 pm
I'd do what Steve and Madjack suggest. I am using this product from Home Depot for all my seams. I had to order it online as it was not stocked locally. Got it in less than a week.
GE 10.1 oz. Gray Door, Window and Siding Polyurethane
Model GE39495 12C
Internet Catalog #107446
Store SKU#506917
Sika polyurethane tube withstands higher joint movement than silicones or other polyurethanes. Superior flexibility and durability. Adheres to wood, glass, metal and masonry.
Price: $4.59 - Usually ships in 2-3 business days
SPECS
Color/Finish: Gray
Application: Window & Door
Clean-up: Solvent
Exterior: Yes
Interior: No
Paintable: Yes
Sealant Type: Polyurethane
UPC CODE: 077027394955
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby cracker39 » Wed Oct 12, 2005 10:11 am
Would you not make a bend of about 2"-3" across the ends of each piece being joined, bend up and back on one, and down and back on the other, then connect the two bends together and clamp or hammer then together to make a watertight joint? If I decide to go with aluminum, I hope to be able to buy in one long piece and I'd need over 20' to cover from back to front.
Dale
cracker39
Images: 233
Re: Aluminum skin overlap
Postby bledsoe3 » Wed Oct 12, 2005 10:25 am
Southern Oregon Bob wrote:I have an aluminum joint across the front top curve. Would you overlap the top to the front so it sheds rain water or the front over the top so it sheds water going down the road? I'm using the carpet glue, but should I use something else at the seam? :thinking:
Bob
Interstate metals up here in the Portland area joins the two sheets with a really slick seam. Norm P showed me his tear and the seam was almost completely flat. It looked great. Check his gallery in the hall of fame. Maybe your supplier could do the same.
bledsoe3
Images: 112
