Great site you guys have here. This is my first time posting, and I am new to the Teardrop world.
I am planning to build a 5'x10' Teardrop using all FRP construction.
My plan is to build a female mold out of 2x4s particle board and hardboard.
Then layup the mold as follows:
3 layers of PVA
2 layers of Gelcoat
2 layers of 1.5oz CSM
1 Layer of 24oz woven roving
1 layer of of 1.5oz CSM
I will be using general purpose polyester laminating resin.
The wall thickness should be about 1/8" and about 2lbs per sq ft.
I will glass some 1 1/2" wood blocks on the inside to attach an inside wall of hardboard to. The wall cavities will be filled with 2lb mix and pour PU Foam.
The cost of the FRP materials will be around $600, but in return I believe I will have a very light, strong, watertight, well insulated tear...
Has anyone tried anything like this? Any suggestions/opinions?
Overkill? Too weak? Crazy?...
Thanks!
Wes
