Miriam C. wrote:
GFCI after the panel in the TD to protect all circuits down stream. I left it off my airconditioner.
Miriam C. wrote:With no grounded drop cord you have no ground. With no ground the GFCI will trip. KISS try the cord first
Miriam C. wrote::? Ok everyone reread your posts.![]()
Worry about screws if something if that fails. And get some wood behind that panel.
Tryed another cord plugged to my RV cord, it tripped.
It will still trip the GFI with the breakers cut off in the box,
My box is grounded to the frame. The frame and wall supports are all metal and the box is screwed to a metal wall support.
Miriam C. wrote:I am wondering why your breaker didn't trip when you got shocked.
jeep_bluetj wrote:Miriam C. wrote:I am wondering why your breaker didn't trip when you got shocked.
Not enough current. Breakers protect ONLY for overcurrent. So to pop a breaker, you'll need to be pulling over the rating of a breaker. In this case, I'd guess the breaker was 15A or 20A. If 15 amps were flowing through madprinter, he would definitely not be "pinin for the fijords," he'd be an ex-printer. Really, to get this much current flowing through a human at 115v, your resistance needs to be _really_ low -- like standing in a salt-water bathtub with a golfclub and a tinfoil hat low.
There IS a short/partial short from hot to _something_. That something is likely the trailer frame. A bit of sleuthing with an ohmmeter will find it. I'll bet it's in your cable -- i.e. the GFI trips, but all breakers in the trailer are off, it's between the plug and the breakers.
Miriam C. wrote:I have just got to ask why? Seriously I really would love to know. I stayed at the motel 6
madprinter wrote:;) Finally found it!!
I don't know how I did it, well maybe it was other self, but I made a major boo boo when I attached my neutral input wire to my box.
I put the wire on the back side of the lug screw, between the box wall and the plastic insulating panel. When I screwed the lug up tight it pushed against the plastic panel and felt secure. It must have been curved back enough to touch the lug some, giving me power. After a few power ups, it must have made contact thru the paint and started the GFI to tripping.
I was really lucky the ground was'nt wet are I would have been the "Ex Printer" as stated. God must be protecting me. I'm off on my first trip this weekend to the Caddo river in Glenwood Arkansas. We'd love to have some fellow members join us. Relaxing, canoeing and getting sunburned.Sounds fun. Thanks to all for the input.William
wlooper89 wrote:Miriam C. wrote:I have just got to ask why? Seriously I really would love to know. I stayed at the motel 6
A good one Miriam!Since the GFCI is looking only at things on the load side or downstream, I suggest the sooner the better in trailer wiring, as soon as possible after the power inlet. Especially if the electrical compartment is metal. One could install it after the circuit breaker(s). But that leaves a little more chance for a short to ground that is not protected by the GFCI.
Bill
wlooper89 wrote:madprinter wrote:;) Finally found it!!
Congratulations on finding the problem! That is a relief to a lot of us. Have a great trip!
Bill
Miriam C. wrote:Yeah buttttttttttt the air conditioner.......If you put it on the incoming side of the circuit breaker it "may" trip a lot. But I get the concept. We have a few who did not do breakers and they do have a GFCI immediately after the inlet.
