wannabefree wrote:Sorry, a lot of these things happen because we don't know what's in the stuff we're using. I swore off poly 30 years ago in part because I had adhesion problems. I also didn't like the look. Poly has improved but I still won't use the stuff. Burned once; won't be burned again. Can't tell you what's wrong, but here's a way to fix it.
Clean off the gooey poly with whatever will cut it. If you have a stain under it this may also lighten the stain. If so, restain with a thinned coat. Let it dry thoroughly. That usually means a week or more if oil based, a couple days for water base and a good day for alcohol soluble dyes. Get a can of super-blond shellac and cut it 2:1 with denatured alcohol. Brush that over your problem area. One light coat will do. Give it at least a day to dry; preferrably 3 or more. Then reapply your poly.
I suggest experimenting on a piece of scrap so you know how much stain to apply to get a color match. If you can't get a match with the stain, add a little dye to your shellac. Transtint is what I use. Get it at a Woodcraft store. The nice thing about using the shellac seal coat to match color is if you get it wrong you just strip it off with alcohol and redo it.
This works because shellac sticks to anything and anything sticks to shellac. The shellac seals in any bad stuff that is interfering with your poly.
A side note - poly still has adhesion problems on oil based stains. To test adhesion, stick a piece of the regular brown masking tape to your poly. Rub it down good and go away for half an hour or so. Then rip up the tape. Hopefully the poly will stay stuck to your wood, not the tape. If it comes up with the tape you have a bigger problem. But you might not want to know that
DURA SEAL™ Polyurethane will have an ambering effect when applied over light colored surfaces. Do not apply DURA SEAL™ Polyurethane over floors previously finished with wax, shellac, lacquer, or stains containing wax or stearates. Allow extra drying time when applying over floors that have been stained. Do not steel wool or burnish the surface before applying DURA SEAL™ Polyurethane. Do not apply DURA SEAL™ Polyurethane during extremely cold or humid weather. Do not close off ventilation after applying DURA SEAL™ Polyurethane. Always screen lightly between coats.
