Kenny wrote;
Seems to me that moisture appears to be enemy number 1 regardless of the material chosen.
48Rob wrote:Kenny wrote;
Aaron,
If your hardboard (masonite) is "coming apart" you haven't got it sealed, or sealed well enough.
No offense, but most people that don't build things that must resist the weather, don't fully understand how important it is to make sure NO weather can get to any raw wood, or wood product.
Just a very small area can wick up a lot of moisture.
Sealing wood is good, but one or two coats may not (usually IS not) enough to fully seal the surface.
...to completely seal wood product REGARDLESS OF PRODUCT USED you will need to do a minimum of 3 coats..the first, will be full of both microscopic and larger air bubbles and voids from evaporating aromatics...the second coat will fill most of the air bubbles and voids but still leave some...the third will pretty well finish up the seal, a fourth, if you have extra product won't hurt...
As Jack suggested, using aluminum directly over the roof supports is fine, as long as it is thick enough to resist sagging and denting.
...use at least .040, we put our spars at 9" centers and put some cross blocking in as well.....
A lot of people that use paneling under the aluminum don't "need to" for support, but choose to for appearance.
Staring up at a cold exposed aluminum sheet can be unattractive to some...
As also suggested, the cheap big box store "paneling" in 1/8" can be used for "looks" (facing the interior) with the aluminum on top.
Be SURE the cheap paneling is real plywood, and not particle board...
...DOUBLE AMEN +10 to that!!!!
(look at the backside, if it is plywood, it will look like real wood, and will be lightweight, particle board/pressed board is very heavy)
Rob
