What should I do?
Jim,
Yep, that's what I thought. So my answer was right on. Damn, I was right again. Don't you just hate it George & Ira.rooster wrote:I forgot to mention that the folds are the same type you see on a camper.
The guy has this machine that makes the folds....Jim
But George, this is a quote in part from my post.GeorgeTelford wrote:Hi Gage
Actualy that proves you are mistaken but unlike yourself I do not intend to gloat, like Ira said unless you could use the twist nails all the way across then twist nails are not the answer, what are the chances of a nailer being in the right spot, secondly all those nails are possible leak points. Also any time you use a different metal to screw or nail down aluminium you start an electrolytical reaction which corrodes the Aluminium.
The answer I have been informed is to lay it down, then using a length of timber and a rubber mallet flatten the Z back down. At nearly 4 ft gaps can you avoid the Z being on a corner?
I do believe I said alum nails and I believe that Jim is talking about alum sheet. Sounds like the same material to me. And what do you mean: "...twist nails all the way across...." He's not building a large RV. And the type of alum skin he has is not made to be glued down but to be tacked on the edges and then the tacks or brads are covered with the trim molding. Instead of asking your friend who probably doesn't even know what a NON-FIBERGLASS trailer/caravan even looks like, go out yourself and take a good look at a Vintage Travel Trailer/Caravan. Then let me know how the skins were attached (below is a picture of one that I restored, the sides and top skins are all floating (as mfg'd), but you need to see one up close).and you can get those alum twist nails from the Teardrop Fix-it Shop
Users browsing this forum: Google [Bot] and 3 guests
