by FireLion » Sun Jul 19, 2009 11:26 am
A new generator is a quick fix, but an old one can be made to work. Steel wool the center rod, the spring can be cleaned with solvent & steel wool. Remove the tip from the generator tube and soak it in solvent also. Blow out the tube with air.
For the burners, disassemble, clean with steel wool, reassemble (be sure to keep the parts in order). With an air compessor, blow out the 'U' shaped fixture behind the main burner, that should clear the tube for the auxilliary burner also.
This has always worked for me.
P.S. make sure that all connections are screwed down tight. A bit of teflon tape on the screw threads helps too.
'How can ya get away from it all if ya take it all with ya?'
2004 Ford Escape Ltd.
2012 Coleman tent-no wheels, no A/C, no hitch
