I started a build in Mo
Postby WayneFromMo » Fri Jul 17, 2009 10:46 pm
Well I started my build here is a few pictures.
Here I'm trying to square the frame.
Here is the trailers top side.
Trying to show the frame with an axel.
The following is how I used a car jack for a stablizer jack.
The only thing keeping anyone from being a genius is motivation- Albert Einstein
My build
http://www.tnttt.com/viewtopic.php?t=31105
WayneFromMo
Images: 92
Postby devigata » Sat Jul 18, 2009 10:04 am
Looks like you have a sturdy base to start with. Keep the pics coming!
What is your favorite profile?
devigata
Images: 82
Postby WayneFromMo » Sat Jul 18, 2009 2:02 pm
I finished the prep on the Frame and painted it.
Do I need the axel overslung or underslung? My hubs fit 14" Wheels.
My build
WayneFromMo
Images: 92
Postby WayneFromMo » Sat Jul 18, 2009 2:28 pm
I Guess I could use a little help on picking a layout. In both profiles I put every thing I needed in first and then worked on the outside.
This is Profile #1. In this profile I cannot use the large window in the rear.
In this profile I can use a large window that I salvaged from a wrecked RV.
Which profile should I use?
My build
WayneFromMo
Images: 92
Postby mikeschn » Sat Jul 18, 2009 3:34 pm
Good looking frame. What's next, the side profile? What flavor are you thinking?
Oh and welcome to the forum!
Postby WayneFromMo » Sat Jul 18, 2009 5:19 pm
Thanks, As far as flavor, I like to keep it simple. I feel it's easier to maintain. I wanted to build a Winter Warrior, but I couldn’t keep it from gapping or binding up in my PRO E. Plus I needed a little more room for my hunting gear and a full size bed. I like the looks of the Benroy TD. I also like the looks of the T@B and R-POD campers. I also was lucky enough to pick up a large window out of an RV. I was maybe hoping to use it. Those windows cost a lot of money new. So I was looking for an experienced opinion on the design. I believe I can still build either one.
My build
WayneFromMo
Images: 92
Postby mikeschn » Sat Jul 18, 2009 5:52 pm
If you want an opinion, go for a curved profile... it's stronger, easier to seal, and looks good.
P.s. here is the beginnings of my mini tab design...
Postby WayneFromMo » Sat Jul 18, 2009 6:32 pm
I've been reading your thread for the T@B, made your mind up on how to build the trim?
Do you think I need to have the axel under the spring or on top of the spring. I'll be using 14" wheel and tires? I'm thinking of putting the axel under the spring it may ride better with my truck.
My build
WayneFromMo
Images: 92
Postby mikeschn » Sat Jul 18, 2009 6:35 pm
I'm planning on using a torsion axle to get it as low as possible.
If changing your axle is not an option, put the axle above your springs to get it lower.
P.S. No, I've not decided anything on the trim yet.
mini T@B link????
Postby John T. Hodgen » Sun Jul 19, 2009 8:18 am
Hey Mike,
I must of missed this new build that you have going on with the mini T@B profile. could you pm it to me, many thanks.
Til later by the fire--John T. 8)
John T. Hodgen
Postby aggie79 » Mon Jul 20, 2009 8:24 am
:applause: :thumbsup: :applause: Nice job on the frame Wayne. I can't wait to see how your build progresses. Keep the pictures coming.
Postby WayneFromMo » Sun Aug 02, 2009 7:45 pm
I framed the floor this weekend. I also managed to seal it. I'm not too worried about the floor. I framed it with pressure treated wood.
So I'll wait for the sealer to dry, flip it over, and bolt down it next week.
8)
My build
WayneFromMo
Images: 92
Postby WayneFromMo » Mon Aug 03, 2009 12:12 pm
Well I'm running into a material problem. I have been looking for some 1/8" thick plywood to use on the outer skin. My plan was to layer it to 1/4" thick. I've called around to trying find some 1/8" thick plywood, no one has any to offer and sale.
So my question is can 1/4" be bent to fit a 24" raduis? If so how would you go about doing so. I have a few toughts, but I would like to hear yours first.
If I cannot find any 1/8". I will have to change my design. :)
My build
WayneFromMo
Images: 92
Postby chief5 » Mon Aug 03, 2009 4:52 pm
You could cover the radius 'ed area with strips resawn on a bandsaw to 1/4" thick. Bead and cove the edges for a tighter fit. Search "Cedar strip canoe" To use less strips, you could use 1.5 inch material to resaw.
chief5
Postby mikeschn » Mon Aug 03, 2009 5:17 pm
I have bent 1/4" plywood over a 24" curve, but it's tough. Best to wet it a little bit... errr... make that "a lot"...
BTW, the nailer didn't work. The nails pulled right thru the plywood. We ended up using roofing nails and a hammer...
I guess I'm fortunate to live near a large city. When the plywood place in Pontiac no longer carried the plywood I wanted, I just called down to a place in Detroit, and had them deliver what I wanted.
Of course, if the place in Detroit no longer sells it, then I'll have to go to Boulter Plywood, just like many of the guys here have done...
http://www.boulterplywood.com/
It might cost a little more than buying it locally, but you'll get exactly what you want.
