MCI1969 wrote: Even a 40lb is hard to compress by hand (tonneau props range from 90 -180lbs)
bbarry wrote:I received my gas springs today from McMaster. I ordered ones with 120lbs force each on the recommendation from several members here. I am completely unable to compress these springs by any non-mechanical means. I'm not a hulking gym-junkie by any means, but even putting one end on the ground and using my entire weight (160lbs) I couldn't get them to budge a bit.
Is this normal? I tried turning the plunger end in case there was a threaded lock of some sort...no dice. I can always put a pipe clamp on them to make certain they compress, but I don't want to force anything. I for sure don't want to install them until I know they're okay.
Ideas? Thanks!!!
Brad
Jiminsav wrote: your puny 160 pounds is fluff to a 120 lbs strut....
girly man.
mikeschn wrote:How do you like the ones from McMasterCarr? got a good close up photo of the end where you screw on the fitting?
mikeschn wrote:I like them...
Is that the model number, the C16-24215?
Jiminsav wrote:the problem is, thats the wrong end for what you want to do. you need a end like these.
bbarry wrote:Jiminsav wrote: your puny 160 pounds is fluff to a 120 lbs strut....
girly man.
I'm working on that beer gut. I'm on a strict regimen of 12 ounce curls.
Brad
starleen2 wrote:bbarry wrote:Jiminsav wrote: your puny 160 pounds is fluff to a 120 lbs strut....
girly man.
Brad
So - How much pressure does it take to collapse a wooden prop rod??![]()
bbarry wrote:Is this normal?
mikeschn wrote:that reminds me, I gotta get some too. How do you like the ones from McMasterCarr? got a good close up photo of the end where you screw on the fitting?
