If you use plywood ribs they should be pretty stable (as opposed to bent wood). If you couple that with bendable plywood or some 1/8 plywood, and epoxy or tight bond the plywood (inside and outside), I can imagine it should change shape too much. Also, if you keep it battened down (latched) it will keep a preload on it which will not allow it to bow back out straight. I forget who it was, but galley latches came up. He had a latch on both sides at the bottom (structurally this is the best place to put it to give maximum mechanical advantage when you are trying to make it conform to contour). I plan on getting around this by hotwiring the hatch out of rigid foam and then glassing it. There won’t be any preload in the door then to try and make it spring back.
One other thing, and I know it’s been mentioned before is to build the hatch first, then trim the tear to match. One advantage doing it that way is you could let it sit for a month or two and it would likely get to a position of quasi-equilibrium and then you wouldn’t have to worry so much about it opening further.
