I've also used this in some of the industrial furnishings I've made. The advantage this has is the fact that it is paintable as is, and you can really achieve a very high gloss paint job if desired. As I stated, since it's an outdoor substrate, it'll last as long as the highway signs you see, because most of them produced at least thru the late 90's used this stuff. It's about 10% higher than regular plywood, but a decent supplier can also supply it in 5X10 foot sheets as well.
Hope I've helped.
![Thumbs Up :thumbsup:](./images/smilies/econ_thumbsup.gif)
