Pat's 49 wrote:Has anyone built a teardrop with 1" square tube and welded the sheet metal to the tube?
toypusher wrote:I would think that 1" square would be way 'overkill' for a teardrop. Half that when you get a skin on it should be plenty strong.
chorizon wrote:
I'd go for 1/2" sq. .060 wall tubing, with 16 ga. (~.060) steel sheet. That way, you'll eliminate any dissimilarities between the different metal thicknesses.
Maybe go thinner on the sheetmetal if you want to cut down on weight.
PanelDeland wrote:Look around for a spot welder.They should work well for this. The jaw length may be too short but the heat and such is controlled and should be up to the task.I do think the welds may show if you are wanting bare steel but with a little filler or some glaze you could paint over it and never see them.
Any welding supply should be able to give you a demonstration of a spot welder.
