Roof - Using 5.2mm Laun - best way to apply
Postby BILLYL » Fri Sep 30, 2005 6:57 am
howdy-
Well I am at the stage of skinning the roof and picked up two pieces of 4x8 laun ply. Since one sheet won't completely cover the roof I will have to use two pieces. My thought is to use a full sheet attached at the galley end and glue and staple it - and then finish off the rest with the remaining piece. Or would I be better off starting at the tongue end and working up to the galley? (This gives me a less visible seam)
Also what is the best way to secure the ply? I have looked at various personal galleys and have seen both wood screws and staples.
Thanks
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Steve Frederick » Fri Sep 30, 2005 7:17 am
Hi Billy!
I start at the front, where the curve is rounder. That way, you don't have a
joint in the ply at the wrong (sharp curve) place. It's very difficult to get a tight seam on edges that are under stress from bending. The center of the seam will want to open up, leaving a gap.
Yeah, I know this first hand :x :x A gap in ply that IS the finish, as in woodies, is not good! It's repairable, but a big hassle. :thumbdown:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Endo » Fri Sep 30, 2005 8:35 am
I started at the hatch and worked my way to the front. I used alot of heavy items on top to hold things in place while the "Gorilla Glue" dried. At the front I screwed some temporary boards over the spars to hold the luan in place. After the glue dried I removed the boards. My seam is in the front but it is not in a curved area so a gap was not a problem.
I still smoothed the seam with some filler prior to installing my aluminum.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby BILLYL » Fri Sep 30, 2005 9:17 am
Thanks for the advice. After I posted the orginal question and since I am building a Cubby (well almost) starting at the tongue and working back to the galley makes sense.
My question to Steve is - besides the glue what other fastners would you use. Since I do not plan on putting another materials over the roof (except some fiberglass) What would you suggest? Also - what is the best type of wood filler to use?
Thanks
Bill
BILLYL
Postby mikeschn » Fri Sep 30, 2005 3:37 pm
Aw, come on Steve, I wanna know too!!!
Steve Frederick wrote:
BILLYL wrote:Thanks for the advice. After I posted the orginal question and since I am building a Cubby (well almost) starting at the tongue and working back to the galley makes sense.
Thanks
Bill
Bill, Check your PM Mailbox!! :thumbsup: :shhh:
Postby BILLYL » Sun Oct 02, 2005 5:07 pm
Steve-
Worked like a champ!!!!!!!!!!!!!!!!!!!!!!!!!!
Took all of 30 minutes to install - am only doing one layer of ply. I also added a board at the bootom to act like a shelve so the ply could rest on it and start the aggressive curve.
One other thing I did was to attach the ply on the frame a few days before - so it gets use to being curved under pressure. Let it sit for a few days and it began to think that it should be in that shape. That helped out a lot.
Thanks again
Bill
BILLYL
Postby asianflava » Sun Oct 02, 2005 10:14 pm
I took one end and glued it down with polyurethane caulk. I clamped it down with at 2x4 on end. It was either screwed down or held in place with a floor jack (the weight of trailer clamping it down.) When it was dry, I removed it and started bending it over the curve. I pulled it with straps while the same board clamped the other end. I would also put screws into it to hold it down.
asianflava
Postby bledsoe3 » Fri Oct 07, 2005 4:19 am
mikeschn wrote:Aw, come on Steve, I wanna know too!!!
Thanks
Bill
Steve, I want to know too. I should skinning my roof this weekend. :worship: Jim
bledsoe3
Images: 112
