Painting a cooler...
Postby Alleged User » Sun Aug 09, 2009 4:31 pm
Rescued a cooler from my in-laws' treasure trove of neat old stuff. Granted, it's a little hard-core, but it's free, and that's for me.
So, we'd like to make a little project of it and repaint it. Any tips on which paint to use to mimic Coleman green? (Or brown...not sure which). We're actually looking for an old upright (who isn't), but we'll use this in the meantime.
Thanks, gearus.
Kelly & Duke
2011 ZZ Drop
Perhaps they are not stars, but rather openings in heaven where the love of our lost ones pours through and shines down upon us to let us know they are happy. - Eskimo proverb
Alleged User
Images: 81
Location: Northern Virginia...not to be confused with Virginia.
Postby doug hodder » Sun Aug 09, 2009 6:54 pm
Rustoleum makes a dark hunter green that I think would pass on it. Rustoleum oil based does take longer to dry however and my experience is that it doesn't have the gloss like some of the others out there. Most of the hunter greens that are available in the spray cans will work and are acceptable with the Coleman crowd. It's not a concours event, it's an old free cooler, so don't sweat the match. I'd wipe the whole thing down with a degreaser, scuff it with a scotch bright pad and spot prime the rust spots, mask it off and paint it. If you want a dead on match....have a custom rattle can matched at the auto paint store. Could run you 20$ though. Nice cooler! Doug
Postby dreadcptflint » Sun Aug 09, 2009 6:54 pm
Oh come on put some flames on it. Everyone will want your cooler after that.
:wakka wakka: :sneakers: :wakka wakka:
dreadcptflint
Images: 19
Postby hotrod » Sun Aug 09, 2009 7:00 pm
rustoleum makes a primer now called rust reformer, might want to try that over your rusty areas after you have them sanded to bare metal..its some fairly odiferous stuff so spray it outside...
Paul
hotrod
TILT
TILT
Postby Alleged User » Mon Aug 10, 2009 8:59 am
Excellent...thanks so much, guys! :shake hands:
Can't wait to get started. I think I'll go with an off-the-shelf paint, in keeping with my thriftycheap sensibilities. Will also check out the Rustoleum primer.
Flames, huh? I'll leave the fancy business to you pros who have the skill and patience...as it is, the crooked Coleman decal is making me twitch. :lol:
Kelly
Kelly & Duke
2011 ZZ Drop
Alleged User
Images: 81
Postby kurtibm » Tue Aug 11, 2009 2:54 pm
I have used Rust-o-leum 'Hunter Green' with very close results and I have seen a couple done with John Deere "Case Green" that looked great.
If I recall correctly, those plastic lids were hollow... I wonder if that expanda-foam 'stuff' could be injected through a hole or something similar in order to increase the R value...?
kurt
It is not the years in your life that matter, it's the life in your years.
kurtibm
Images: 29
Postby Alleged User » Tue Aug 11, 2009 7:34 pm
Yes, the lid is indeed hollow. Interesting idea on the foam. :thinking:
Kelly & Duke
2011 ZZ Drop
Alleged User
Images: 81
Postby Dark Horse » Tue Aug 11, 2009 9:01 pm
The Window and Door stuff would be the preferred option for the stuff in a can, and a cooler day to help limit the expansion. the regular stuff expands way too much.
I like anything that turns money into noise.
Dark Horse
Postby rebapuck » Wed Aug 12, 2009 8:32 pm
hotrod, can that rustoleum primer be used on a car? I've got some rusty crusty windshields I need to take out and I'm afraid of what I will find.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby hotrod » Wed Aug 12, 2009 9:16 pm
rebapuck wrote:hotrod, can that rustoleum primer be used on a car? I've got some rusty crusty windshields I need to take out and I'm afraid of what I will find.
I would think so.. I primed my impala floors after I was done patching the rust holes then sprayed truck bed liner over it, no problems yet..
I would be sure to get as much of the rust out as you can, then prime the areas. odds are if theres a windsheild theres a seam handy and the rust will be tough to remove..
Paul
hotrod
TILT
TILT
Postby robertaw » Thu Aug 13, 2009 8:51 pm
Oh my gosh, are we related? ;)
Roberta
robertaw
Images: 56
