48Rob wrote:I'm with Coop, but would also add a bit of "mechanical" bond to both by using 240 grit sandpaper to "break" the surface.
Masonite is a great product, and can last 50+ years outside if properly sealed.
Just make sure ANY exposed part is fully sealed.
If you use Poly, be sure it is rated for outdoor use.
Marine Spar varnish is better able to withstand movement of the surface it is applied too (stretchy...).
Rob
Good, we have responders.lol.. I am thinking about my next build which I will discuss later. My current tear,I put Luan on the roof, went on just fine however, I used A grade fir on the sides and I hate the red top with the brown fir sides. YUCK or, maybe it is just me. Getting ready to throw some metal over that nasty polycoated luan.....lol.. now, back to the masonite. It would seem if someone wanted to build a cheap tear for someone with little money, this may be an option to knock out a 1/2 inch sided trailer with masonite top and a simple galley and shelf for tv/radio in the cabin. No frills, just a good shaped tear with little outlay. We all tend to overbuild including myself. I have some other designs I have drawn up for a cycle teardrop(oak with a flat oak roof(woodie) hard to explain without seeing it but it would be low profile(42") and a shorty 76 inches long.goldcoop wrote:Danny-
I think for enamel finish I would use a "bonding primer"
For Poly or Marine Varnish I think I would use a thinned 1st coat & go from there.
JMO...
Cheers,
Coop
starleen2 wrote:I used the 1/8 masonite on the first two builds. worked well until I got a leak and the stuff turned into mush!! Masonite will bend around the radius that most teardrops use - but the tempered type will break at a certain point! Now I use 1/8 paneling so I don't have to worry about leaks or sealing both sides. When I'm done - I want to be done. Learned the hard way - and won't look back
