Right above my belt......
Toytaco2 wrote:On a shelf attached to the underside of the frame at the rear of the trailer. The extra weight of the spare helps offset the battery in the tongue box. Yes, those are huge zip ties (175lb tensile strength each) securing the spare to the shelf. Seems to be real solid and tight.
Mike
bobhenry wrote:P.S. you might need a jack too!
