mikeschn wrote:This summer I played with biscuit joints in plywood. Below is a picture of what I used biscuit joints on... The walls are plenty strong as long as you are careful moving them. I would not apply any real pressure on the joints until I have the 5.2mm luan glued on both sides of that joint.
cracker39 wrote: which I'll lap joint with the verticals. The other pieces I can biscuit join where needed. That should make for a pretty stable side wall.
