I read somewhere that it was best to use stranded wires instead of solid because vibrations could break the solid wires. But in the Gen Ben plans you can clearly see the 120V outlets wired with Romex.
Thoughts? Input?
Also, if going with the stranded SO cord, would it be beter to crimp on a spade conector or just twist the wire and clamp 'er down?
