reege
To build by taking 3/4" plywood and cutting out the frame work similar to option one stick frame with 1/8-1/4" skin is another option. Might be the best of both worlds.
kennyrayandersen wrote:Keep in mind that a lot of the waviness of the thinner plywood will straighten out once you nail it all down (even if it’s just to the framing – this would be especially true of you use your shop vac and bond the skins to the frame and core).
aggie79 wrote:kennyrayandersen wrote:Keep in mind that a lot of the waviness of the thinner plywood will straighten out once you nail it all down (even if it’s just to the framing – this would be especially true of you use your shop vac and bond the skins to the frame and core).
It will straighten out only if it is on a flat surface when you are applying the skin.
I am using 3/4 MDO plywood "framing" with skins both sides. While there is a lot of waste in this method, the plywood doesn't cup, twist and/or warp like stick built framing has a tendency to do.
regis101 wrote:5 x 12 and only weighs 72#. Impressive. I suppose that the pink panels also get a spread of glue?
