TD Plans for an accessable trailer (handicap)
Postby Trooperchix » Thu Oct 13, 2005 9:16 am
Hi, I am a recently bitten teardrop covetor, and I want to build one. I want to get some input as to plans. Here's my deal. My better half has a debilitating disease, therefore I need space & a strong enough construction that I can place handrails in anticipation of loss of mobility. Also, we are kinda roomy folks, so need a king sized bed in it set up in such a fashion as to allow us each our own doors to get out without waking the other for that midnight trot to the biffy. Oh, one more thing, we live in Minnesota, so it has to be capable to be insulated well. I've looked at so many plans... my head is spinning. Any ideas? Has someone else run into this same issue? Thanks for all your help.
I ain't too bad with a tool for a girl... :)
Trooperchix
Postby cracker39 » Thu Oct 13, 2005 10:35 am
Maybe it's because I just like it, but Andrew's compact comes to mind. It has a rear door that could have a ramp built to access with a wheel chair if that becomes necessary. Widened, it coud take a King bed, but maybe a Queen would do with this type of trailer. It's a little larger than a TD, with standing room which is why I like it. My wife is claustrophobic and can't take really tiny spaces, or those that are too enclosed. She too has a delibating disease, so I need all the convenience I can get on our tiny budget.
http://www.angib.pwp.blueyonder.co.uk/teardrop/tear48.htm
Dale
cracker39
Images: 233
Postby cracker39 » Thu Oct 13, 2005 10:42 am
Or, check out my design that I plan to build soon. Click on both the model link and the link at the bottom to see the layout diagrams.
http://home.tampabay.rr.com/wdsummers/squidgethome.html
Dale
cracker39
Images: 233
Your plans rock...
Postby Trooperchix » Thu Oct 13, 2005 11:16 am
Very workable, I can modify it slightly to meet my needs... I am interested in your plans when you are done, but I may also be building it simultaneously as you are. I on the otherhand won't be able to start it until the dead deep of winter (probably December, most likely January). I'm going to keep looking, but I think you just sold me on your plans... My better half too is clausterphobic & wants to be able to stand.
Again, most excellent...
Trooperchix
Re: TD Plans for an accessable trailer (handicap)
Postby mikeschn » Thu Oct 13, 2005 3:19 pm
Trooperchix wrote:Hi, I am a recently bitten teardrop covetor, and I want to build one. I want to get some input as to plans. Here's my deal. My better half has a debilitating disease, therefore I need space & a strong enough construction that I can place handrails in anticipation of loss of mobility. Also, we are kinda roomy folks, so need a king sized bed in it set up in such a fashion as to allow us each our own doors to get out without waking the other for that midnight trot to the biffy. Oh, one more thing, we live in Minnesota, so it has to be capable to be insulated well. I've looked at so many plans... my head is spinning. Any ideas? Has someone else run into this same issue? Thanks for all your help.
Well at first blush I thought you could build a 6' wide Generic Benroy. You can make it plenty durable, and add rails and all that stuff...
But reading further, it sounds like you are after something more like a T@B. You could build your own home made tab... add the rails... be able to stand in it... and even cook in it in the middle of your MN winters...
Something like this interest you?
Actually I thought I had photos of a homebuilt much closer to a tab, but I can't find them now... (Did anyone else save the photo of the homemade Tab off of Ebay a few months ago?)
Postby Gerdo » Thu Oct 13, 2005 4:11 pm
Mike
That thing is cute!
Gerdo
Images: 156
Postby mikeschn » Thu Oct 13, 2005 5:23 pm
Here's an inside view...
Postby Spadinator » Thu Oct 13, 2005 6:30 pm
What trailer is that little red one? I like it!!! :thumbsup:
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby mikeschn » Fri Oct 14, 2005 2:07 am
All I know is that it's called a Knaus. Maybe if you have some time to do some web searching...
Or maybe Andrew can make us a profile drawing.
In the meantime here are my remaining photos on it...
Postby bledsoe3 » Fri Oct 14, 2005 3:58 am
mikeschn wrote:Actually I thought I had photos of a homebuilt much closer to a tab, but I can't find them now... (Did anyone else save the photo of the homemade Tab off of Ebay a few months ago?)
Here is a link to it Mike.
http://cgi.ebay.com/ebaymotors/2002-12-vintage-clasic-tear-drop-50s-60s-style-camper_W0QQitemZ4571360940QQcategoryZ50063QQtcZphotoQQrdZ1QQcmdZViewItem
bledsoe3
Images: 112
TAB..
Postby Trooperchix » Fri Oct 14, 2005 7:24 am
That thing looks great too. I really want a true teardrop with the galley in the back, just makes it feel like camping more, but I'm game on anything at this point. Does anybody have copies of plans I can peruse? I don't want to spend money on plans right now until I know it is something I can build with my limited building experience, that the layout will work well and that it is truly what I want. That and my better half would have my behind in a sling if I blew a hundred bucks on plans and not use them. Does that all make sense? Anyway, if you have any, you can email them to [email protected] (take the "nospam" out, trying to keep off the junk email lists).
Thanks guys,
Trooperchix.
:D
Trooperchix
Oh, and..
Postby Trooperchix » Fri Oct 14, 2005 7:25 am
I do like the look of the Benroy... What was the other one... plans based of the Kampmaster or something of that sort...
again, thanks.
trooperchix.
Trooperchix
Postby Spadinator » Fri Oct 14, 2005 8:13 am
Thanks Mike....I will do a little research!!!
Spadinator
Images: 47
Postby Spadinator » Fri Oct 14, 2005 9:51 am
Ok Found info on the trailer!!! :thumbsup: It is a 1962 Knaus Caravan.....also known as the Swallows Nest. Body length is 7'6" with a width of 6' and an internal height of 6' as well. COOL little trailer!!! :chicken:
Spadinator
Images: 47
Postby mikeschn » Fri Oct 14, 2005 2:39 pm
Here's another one for you to think about... A homemade Tab clone...
