construction continues on the Menehune Swoop!
Postby S. Heisley » Mon Aug 17, 2009 8:56 pm
Interesting and beautiful profile! You're doing a great job. Thanks for sharing information on your build. :thumbsup: :applause:
Postby Juneaudave » Mon Aug 17, 2009 9:01 pm
I have to agree with all of the above...you are doing a beautiful job!!!! :thumbsup:
Juneaudave
Images: 380
Postby Oasis Maker » Mon Aug 17, 2009 9:13 pm
dmckruit wrote:
I do have a safety concern about the use of the dry ice box. As the dry ice evaporates it gives of carbon dioxide gas. Carbon dioxide is heavier than air, so my concern would be if it were to leak into the sleeping cabin, it may cause the occupants to suffocate. I would be careful here, and maybe put a vent somewhere for the gas to escape.
teardrop_focus wrote:
I've been pondering vent alternatives to the ubiquitous ceiling vent fan... and perhaps for your cooler we can devise a very small 12V vent system complete with a tiny fan to exhaust the CO2... it could be swiiched on when retiring... but you'd also need an additional micro-orifice in the cooler shell to allow air to enter the cooler.
This would be similar to the vent layout I'm thinking of to vent my deep cycle 12V storage battery, since it will be buried within the teardrop near the trailer axle
Yup, again and again, it's pretty cool the knowledge, information, and support that's shared here. Great build by the way too! :thumbsup:
Scott G.
Oasis Maker
Images: 187
Postby 2bits » Mon Aug 17, 2009 9:34 pm
There has got to be alot of info on the dry ice thing on the internet, try some google searches and report back! If the coolers is sealed and no where near connected to the cabin, I'm not seeing the worry though personally. You will have ventilation in the tear anyway correct? You want to have a little fan going at all times, like a computer fan even when the weather is great just to bring in O2 and mix things up a bit. Might want to not worry about venting the cooler and focus on a couple of super quiet tiny low level fans in the cabin because that is an issue cooler or not because of the excellent point of CO2 being heavier than O2 in such a small box.
Thomas
2bits
2bit Member
Postby 2bits » Mon Aug 17, 2009 9:56 pm
Did I mention that it looks freakin AWESOME! !! !
I like the trim sooo much I WISH I woulda held off and did my side trim before putting on the roof trim! Looking excellent!
Thomas
2bits
2bit Member
Postby Miriam C. » Mon Aug 17, 2009 10:11 pm
:applause: :thumbsup: :thumbsup: Oh how cute........Awesome build you have going. If you decide to use dry ice you might seal the box with some pvc shower liner. It used pvc cement. Really I would use it anyway to keep any liquids contained.. btw are the doors to be insulated? Or did I miss a picture? :oops:
Keep up the good work! :thumbsup:
Postby green_eyed_diablito » Tue Aug 18, 2009 12:40 am
thank you all for the kind words...it's motivating! i feel like i'm sharing the build with friends...friends with really good ideas.
i have been reading-up on the off-gassing of dry ice, and i'm learning that CO2 would be contained with the way i have sealed the ice box. but it's a big chance to take so i am strongly considering the fans like some of you have suggested. my only concern is loosing cold...i want to figure out a way to vent and retain cold at the same time. i may be asking for too much.
miriam, you didn't miss a pic. the ice box doors will be insulated and weather stripped to keep in all that good cold! the hatch will be insulated too in order to control galley temps.
it's dark out and all i'm doing is watching TV. i desperately want to go outside and work on the TD instead! this has become an addiction...a fun addiction.
Since this life here and now is all we can know, our most reasonable option is to live it fully.
green_eyed_diablito
Postby teardrop_focus » Tue Aug 18, 2009 1:29 am
Let there be light... several lights. Nothing's more annoying than working at night under one light source and always battling the shadows... Image
:dancing
teardrop_focus
Images: 127
Postby planovet » Tue Aug 18, 2009 8:59 am
green_eyed_diablito wrote:i feel like i'm sharing the build with friends...
...this has become an addiction...a fun addiction.
double :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby David S » Tue Aug 18, 2009 10:48 pm
Wow! thats lookin good, :applause: keep up the good work,
David. :thumbsup:
David S
Images: 53
Postby green_eyed_diablito » Tue Sep 08, 2009 10:49 am
construction has slowed because of the heat, but i finally got out to the back yard to do some more work on the Menehune.
i installed both interior door frames. the frame is blind-doweled for strength. the long piece on the left hides the seam (where i joined two sheets of ply) and hides the porch light wires that drop down from the ceiling. i routed a channel on the backside for the wires. i think i will add a piece to the right side so that side extends to the ceiling as well.
i built a box (from scraps) that will house the one switch that will control both porch lights. i'm going to try my hand at carving and carve a tiki head on the box cover.
the door frame is 3/8" smaller than the door opening so that it can accomodate a rubber seal.
and as a plus, i found a vintage insulated jug at an antique store for $10!
green_eyed_diablito
Postby dmckruit » Tue Sep 08, 2009 2:09 pm
green_eyed_diablito wrote:i have been reading-up on the off-gassing of dry ice, and i'm learning that CO2 would be contained with the way i have sealed the ice box. but it's a big chance to take so i am strongly considering the fans like some of you have suggested. my only concern is loosing cold...i want to figure out a way to vent and retain cold at the same time. i may be asking for too much.
I've been thinking about your icebox dillemma. What if you were to build a smaller ice box (or boxes) and put it/them inside of your existing ice box? Then you would have several options. You can either remove them and store them outside when you are occupying the cabin, or you can install an exhaust fan in the galley icebox. Any gases coming from the smaller boxes would then be exhausted to the outside by the fan.
dmckruit
Images: 212
Postby planovet » Tue Sep 08, 2009 2:45 pm
green_eyed_diablito wrote:and as a plus, i found a vintage insulated jug at an antique store for $10!
Nice find! We found one too on an outing in May. Nice progress so far :thumbsup:
ImageMark (& Cindi)
planovet
The Cat Man
Postby 2bits » Tue Sep 08, 2009 7:43 pm
Yeah, I was just thinking another strip on the top right side would make it look balanced! It's looking good though!!
Thomas
2bits
2bit Member
Postby green_eyed_diablito » Wed Oct 07, 2009 9:32 pm
hello all,
construction has been slower than i'd like...dang life keeps getting in the way. :D
i finally had a chance to make some more sawdust this weekend!
The doors are on! The trim is 2.5" wide, but I used 1.5" trim on the door frame because the width would be doubled by the door's trim.
There was no way to center the handle on the door trim, so I had to add a little bump. It would have worked without the bump, but I didn't like how it looked.
Each side will have a porch light controlled by one switch for both lights.
I made my own bus bars with 1/8" aluminum and 1"x3" poplar (all scrap pieces). All the lights and outlets will route through here, then to the battery. I will build a box with a lid around these pieces.
green_eyed_diablito
