Side table hardware revisited
Postby ken and nettie » Wed Sep 09, 2009 6:53 pm
I know this has come up before (used the search function :) ). Some of the links are dead and some pictures are no longer active. I was hoping to come up with a easy way to attach my 3/4 inch thick ply side table to the side of my tear. I was hoping that someone may have an idea besides the extruded aluminum hardware made for this. I was hoping to run out to the local hardware store sometime tomorrow. Thanks in advance! Pictures of your creative mountings welcome!
Ken
ken and nettie
Postby madjack » Wed Sep 09, 2009 11:24 pm
...see if any of your local stores have "lift off" hinges...these split apart and can be used for mounting a side table...Camp-Inn sued to use something similar for there mounts...the down side is rigging a "lock" so they can't come apart while using...add an adjustable paint pole for the leg and you will be good to go.....
madjack 8)
http://images.google.com/images?gbv=2&h ... =0&ndsp=20
Postby Mike Angeles » Thu Sep 10, 2009 5:40 am
Ken, I borrowed this idea from a forum Member, Few more pictures in my Album.
Mike
tact /takt/ –noun
1. a keen sense of what to say or do to avoid giving offense; including the ability to speak or act without offending.
2. a keen sense of what is appropriate, tasteful, or aesthetically pleasing; taste;
Mike Angeles
Images: 76
Postby 48Rob » Thu Sep 10, 2009 7:06 am
Ken,
If the table can be "left on" the side of the trailer, a plain old piano hinge works well (stainless steel is best, for no rust).
Rob
48Rob
Postby ajricher » Thu Sep 10, 2009 8:29 am
Funny you mention it - I just finished doing up the removable table for my TTT.
Here it is, in place inside the Overlander as it sits at present.
To hold it in place inside or out I used the classic 2-part aluminium extrusion that classic campers used - one part on the table, one on both the outside of the camper and the inside for the enclosed dining area.
I don't have the seller's name handy, but if you do a search of the site for table mounts it should show up (I found it here).
One really neat extensible leg idea I saw here was a crutch - didn't like the aluminium look though. I did mine from an old bentwood maple crutch - a flea-market special at $3/pair.
Stripped the finish, re-stained it to match the interior wood, and fitted it with a pivot/locking mechanism that is no more than some doweling, metal bar and two blocks of hardwood.
ajricher
Here's mine!!
Postby Uncle Chan » Thu Sep 10, 2009 9:37 am
I've since added brackets to each side of the TD so I can put tables there. But, most likely, I will use them for a vertical gun rack, towel holder, etc.
This is where I got my brackets:
https://www.berrylandcampers.com/rv-par ... ge=30&js=n.
Uncle Chan
Uncle Chan
