by dlmarti » Wed Sep 16, 2009 4:15 pm
OSB is around 20% heavier.
OSB is structurally stronger and dimensionally more accurate than plywood.
Once OSB is cut/nailed/screwed, OSB looses its waterproofing (you did say exterior grade right?).
If OSB is penetrated by moisture your done, the seepage rates are MUCH higher than plywood.
Personally I would use plywood, and still go nuts sealing it. If plywood gets wet you can deal with it, with OSB its a total loss.
Also given the fact that OSB has to be treated after cutting/nailing/screwing, I'm not sure you are saving any money.
Do some google searchs and try to glean the facts. OSB isn't the devil like many builders would have you believe. It actually is a superior product in many ways. I just wouldn't uses it on a trailer. Too many transient loads/stresses, and too much moisture.
EDIT: Also I just read that OSB can't carry the screw/nail loads like plywood can. So great on floors, or over structural members, but lousy AS structural members (at least ones that use screws/nails)
