Anyone try metal and wood sandwich frame?
Postby TD Beej » Tue Sep 22, 2009 5:34 pm
I'm thinking about how to make my frame and had the idea of using a wood frame with aluminum top and bottom plates bolted through to make a stiff sandwich. It seems like it would be lighter then steel tubes and smaller dimensionally and maybe less prone to fatigue then aluminum tubing alone.
Thanks,
Beej
TD Beej
Images: 74
aluminum
Postby laoutdoorsman » Tue Sep 22, 2009 7:11 pm
aluminum is soft...it will bend/flex with the wood...
just my opinion...
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
Postby Ageless » Tue Sep 22, 2009 7:23 pm
They have a product called 'Signboard' which had aluminum bonded on both sides. It is very rigid as the aluminum does not want to compress and flex at the same time. It's 1/2" marine ply. I have several sheets that Boeing threw out, so I packed them home. This is pricey stuff; about $60 a sheet
Ageless
hmm
Postby laoutdoorsman » Tue Sep 22, 2009 7:30 pm
Ageless wrote:They have a product called 'Signboard' which had aluminum bonded on both sides. It is very rigid as the aluminum does not want to compress and flex at the same time. It's 1/2" marine ply. I have several sheets that Boeing threw out, so I packed them home. This is pricey stuff; about $60 a sheet
interesting...i never heard of it..
laoutdoorsman
Images: 44
Postby TD Beej » Wed Sep 23, 2009 1:06 am
Ageless,
Do you know the brand of the signboard? I did a search and was coming up with all kinds of different products. Any idea how stiff it is relative to say the same plywood w/ a fiber glass layers on each side.
Thanks,
Beej
TD Beej
Images: 74
Postby Arne » Wed Sep 23, 2009 8:12 am
There are different types of aluminum. If you select the proper grade, you would have no problem. If you get the wrong grade, it will bend and stretch.
Ather grade of aluminum alloys: http://www.aluminum.org/Content/Navigati
4xx.x - Al-Si Alloys
5xxx - Al-Mg Alloys
6xxx - Al-Mg-Si Alloys (like 6061,6063, and 6111)
5xxx alloys find wide application in Building construction,highways structures including bridges, storage tanks and pressure vessels, and marine applications.
6061 alloy finds broad use in welded structural members such as truck and marine frames, railroad cars,and pipelines.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby TD Beej » Wed Sep 23, 2009 9:58 am
Arne,
Thanks, I hadn't considered the question of the specific alloy.
Thanks,
Barry
TD Beej
Images: 74
