will it work
will it work
Postby stjohn » Mon Oct 17, 2005 1:45 pm
I could not find any unfibered roof coating in my lowes found this at tractor supply :thinking:
product description
Fence posts black beauty made from select asphalts,oils and rust inhibitors
this product penetrates into wood and metal surfaces enabling it to bond to substrate and provide a tough weatherproof finsh it provents rot decay
and termite infestion on wooden surfaces while acting as an anticorrosive coating and rust stopper on metal surfaces
mike
Only he who attempts the ridiculous
Can achieve the impossible
stjohn
Images: 68
Postby stjohn » Mon Oct 17, 2005 1:51 pm
Heres a pic of the can its made by gardner asphalt corpImage
Mike
stjohn
Images: 68
Postby IraRat » Mon Oct 17, 2005 2:13 pm
I guarantee you it's the exact same stuff in that can that it's in MY Gardner's can, which is labeled for roof use. This might be of a little thinner consistency, the roof stuff is pretty gooey, so maybe you'll want to do 2 coats. But if it IS gooey, one is enough.
Same stuff, different packaging.
--Ira
IraRat
Forum Storyteller
Postby madjack » Mon Oct 17, 2005 3:14 pm
...Mike I do believe that will work just fine...the key word on the label is "penetrates"
madjack 8)
Postby stjohn » Mon Oct 17, 2005 11:15 pm
Thanks Ira and Jack I'm concerned it's not like the stuff I've read about on this sight It smells like tar but dries very fast first coat 35min put on the second coat completely dry in 2 hours but it does penetrates I cut my stiring stick and you can see it in the grain.
Thanks again Mike
stjohn
Images: 68
Postby IraRat » Tue Oct 18, 2005 7:19 am
It'll be fine, I'm sure. My stuff stayed gooey for awhile before drying, but that might have had to do with the high humidity down here.
It's main purpose is to protect the underside while you're driving and it's raining. Some people even just use paint, and they keep an eye on it over time to make sure it's still covering good.
--Ira
IraRat
Forum Storyteller
