3/8" Wall Thickness
3/8" Wall Thickness
Postby Jst83 » Thu Sep 24, 2009 9:17 am
Is 3/8" to thin for the middle section on a sandwich built wall. I've got the line up :worship: on 10 sheets of 4x8x3/8" plywood for $5 hear at work (that's total)
Trailer will only be 42"x7' ulta light if that helps with the answer.
Thank You
Jst83
Images: 215
Postby bobhenry » Thu Sep 24, 2009 10:10 am
My chuckwagon is 40" w by 78" long and I only used 7/16 osb. I think it will be more than adequate for what I am doing. The sidewalls wiggle a bit now but once the galley wall is in this will disappear.
You probably won't have a galley wall to stiffen it up will you?
That wiggle would be my only concern. Will it be teardrop shaped or more squared off.
Postby Ageless » Thu Sep 24, 2009 11:38 am
With 1/4" skins? I believe that would be sufficient as some folks have been using a single thickness of 3/4" ply for sidewalls.
Ageless
Postby aggie79 » Thu Sep 24, 2009 11:53 am
With skins, 3/8" should be plenty strong. You may have a challenge finding 3/8" insulation if that is the way you are going. Or, you double up the 3/8" and have a 3/4" void.
Like Bob said, my walls (with the inside skin only) were a little floppy initially. Once fastened to the floor (lap joint), bulkhead, and roof, all the play went away.
Postby Jst83 » Thu Sep 24, 2009 3:26 pm
bobhenry wrote:Will it be teardrop shaped or more squared off.
The MiniGrumman floor space 42"x6'
Here's the profile I've added lines for placement of a galley shelf and a thin cabinet reachable from both sides there will be no under the counter cause feet will go to the back. I do think I'll split the back to hinge down and up so I can slide a mattress in under the counter.
Jst83
Images: 215
Postby mikeschn » Thu Sep 24, 2009 4:11 pm
I wonder if there would be any warping problems with 3/8" plywood?
Other than not being able to get much insulation in there, I don't see any other problems... you weren't planning on taking that to the Shiveree were you?
Postby Jst83 » Thu Sep 24, 2009 4:20 pm
mikeschn wrote:I wonder if there would be any warping problems with 3/8" plywood?
If I sandwich 3/8" outside plus my interior wall it would be over 3/4"
Not really an issue if I can't get the wood from work I'll be going 1/2":( which is up in the air
I just can't pass up that price
mikeschn wrote:Other than not being able to get much insulation in there, I don't see any other problems... you weren't planning on taking that to the Shiveree were you?
Well yes,
Not much insulation but more than my brother had with his popup.
In that small a space I figure it will be to hot I'll have to open the window, I about roasted out of mine last Jan.
Jst83
Images: 215
Postby mikeschn » Thu Sep 24, 2009 6:00 pm
I'm out of vacation time for this year, but that resets in Jan. Will you send me a note when you know some more details about your next Shiveree. I'd really like to try and make it this time...
Postby Ageless » Thu Sep 24, 2009 6:07 pm
At that price; I'd buy it and find a use for it!
Ageless
Postby Jst83 » Thu Sep 24, 2009 6:14 pm
mikeschn wrote:I'm out of vacation time for this year, but that resets in Jan. Will you send me a note when you know some more details about your next Shiveree. I'd really like to try and make it this time...
You got it we'd love to have you it's a blast really.
Jst83
Images: 215
Postby mikeschn » Thu Sep 24, 2009 6:17 pm
Ageless wrote:At that price; I'd buy it and find a use for it!
I agree...
Looking forward to it. Are there electrical hookups, or do I need to bring my
Postby Jst83 » Thu Sep 24, 2009 6:21 pm
brb
Yes there's electric, Last year we set up a 10x20 tent to have our pitch in in.
Jst83
Images: 215
Postby bobhenry » Fri Sep 25, 2009 1:45 am
I really like your profile that will be a sweet little sleeper trailer.
That upper bulkhead and shelf will stiffen up the walls a bunch.
We are thinking on the same lines. I want a tiny sleeper
and tow the mobile kitchen in tandum when I go to
the gatherings.
On another note if we are gonna entice Mike down
for the Shivaree perhaps we should go north this
will help Jim and Karl as well. Potato Creek in
North Liberty or Tippecanoe River state park
in Winamac ? :roll:
Postby bobhenry » Fri Sep 25, 2009 1:54 am
Jst83 wrote:
brb
outside 7 degrees with a 32 MPH wind inside a balmy 46 degrees. Thanks again Jeff for our big party tent!
Postby jplock » Fri Sep 25, 2009 7:17 am
I used 3/8th inch plywood on the outside walls of the windsong. It has had no problems with warping. It is now 3 years old.
jplock
Keep smiling!
jplock
Images: 233
