doug hodder wrote:If you are thinking that you can lay up the glass yourself on the exterior....it can be done. John (Gaston) did a very similar application on the Snoozer (RIP snoozer). It takes a ton of time/ effort and money to get the look that he had. Not a treatment to do short cuts on as it will show in the final finish. Maybe I'm reading your question incorrectly however. Do you want to use pre-made flat sheeting? Doug
starleen2 wrote:Question for all you fiberglass experts. I’m thinking about building a building technique whereas the walls, roofline are sandwich construction. - 1/8 paneling in the inside, furring strips & ¾ inch foam insulation - outside is two layers of woven fiberglass epoxy. The Flooring will remain ¾ plywood. In other words – the inside will be finished traditionally in paneling – while the entire exterior is encapsulated in fiberglass cloth – thus eliminating any seams. Can this be done?
mikeschn wrote:That's what Frank did on the weekender. It has a really beautiful finish. But then he likes doing body work, and I can imagine, there's lots of hours in that finish. The pictures don't really do it justice, but you can see them here...
http://www.mikenchell.com/Weekender_Pho ... ndex2.html
starleen2 wrote:mikeschn wrote:That's what Frank did on the weekender. It has a really beautiful finish. But then he likes doing body work, and I can imagine, there's lots of hours in that finish. The pictures don't really do it justice, but you can see them here...
It looks like He did the exterior in a plywood skin then layered it in fiberglass - What I'm thinking is leaving off the plywood substrate and Just cover the exposed foam and furring strips with Fiberglass cloth and epoxy - I'm also thinking about for a winter project - re making the hatch for the ladybug in a composite fiberglass foam core hatch for a lighter weight - since MRS starleen won't let be build another for another year - so sad
Ageless wrote:F/G is laid up/cured; .023" thick
