awnings
awnings
Postby laoutdoorsman » Sun Sep 13, 2009 2:27 pm
ok...not set on this yet...still too far off...but its still been raining, and cooped up in thehouse for too long....anyway....
thought somebody might be interested in these home-mede awning ideas..
simple
http://www.pcoa.org.au/forum/viewtopic. ... 99a78e7a16
lil more complicated
http://www.lcool.org/technical/sunshade/sun_shade.html
again..i dont know that i would do one of these...just looking...but i do kind of like the simplicity of that first one....
anybody got anything better??
in fact...how about pics of your campsites in action?? no dedicated section of the forum for this that im overlooking is there??
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
Postby mikeschn » Sun Sep 13, 2009 3:01 pm
Here's some window awnings that we saw this past week. Now I know you are not looking for window awnings, but perhaps you can apply the same idea to your roof awnings.
Postby Endo » Sun Sep 13, 2009 6:53 pm
The first link you posted reminds me of the Kelty car tarp.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Rope and Pole Awning
Postby Kristi Foster » Fri Sep 25, 2009 10:12 am
Have you considered a basic Vintage Look Rope and Pole awning that slides into an awning rail? By request, I am using some of my small remnants of Sunbrella and adding No-See-Um netting for a small bug free enclosure.I am also working on an easier set-up without tie downs. I hope to have the new ideas to present at the Georgia Rally.
http://www.vintageawnings.blogspot.com
ebay power seller: dlf1954
See pictures of my Vintage Trailer Awnings in my personal gallery.ImageImage
Kristi Foster
Images: 22
Postby rebapuck » Fri Sep 25, 2009 8:50 pm
The second may be a little more complicated to build, but in the end, it would be easier to use.
I had a sailmaker sew my Puck awning. Just a 7 X 9 in Sunbrella with awning rail welt. I'm considering adding a rail to the VW. If I have welt on both sides and park paralell, then I would need just the center ridgepole.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby doug hodder » Fri Sep 25, 2009 9:04 pm
I used 2 adjustable poles, 2 ropes and some studs on the trailer edge, as opposed to the track, it fits on either side. It's a real eye catcher and I love it! Doug
Postby aggie79 » Fri Sep 25, 2009 9:32 pm
doug hodder wrote:I used 2 adjustable poles, 2 ropes and some studs on the trailer edge, as opposed to the track, it fits on either side. It's a real eye catcher and I love it! Doug
Very nice Doug. How about a close-up of the stud if you get a chance?
Postby doug hodder » Fri Sep 25, 2009 9:57 pm
The stud has a screw base and a twist top to hold the awning in place. It's typical of what used to be used on boats and older cars with canvas tops. The real good idea I had was to use some shock corded glass poles, cut down to fit the awning. I had Marti sew in some pockets in each corner with a piece of velcro to hold them in place in the center of the top. I'm 6'2" and can stand under it with no problem, much higher than the side of the tear where it is attached. They really punch up the flat surface of the awning, and it won't collect water....it survived the Dam Gathering and we got 6 inches of it there, awning up the whole time. Worked for me. Doug
Postby kirkman » Sat Sep 26, 2009 10:04 am
Doug.... Where did you get your studs? That is exactly what I need for mine.
kirkman
Images: 55
Postby doug hodder » Sat Sep 26, 2009 12:06 pm
I got them from Marti when she did the awning. I specifically asked for that type mounting system. I don't know of an exact source, but there should be plenty of them around to get them from. Doug
Postby kirkman » Sat Sep 26, 2009 12:20 pm
Thanks Doug! :thumbsup:
kirkman
Images: 55
Postby Endo » Sat Sep 26, 2009 2:13 pm
kirkman wrote:Doug.... Where did you get your studs? That is exactly what I need for mine.
Here is a source
CLICK HERE
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Oasis Maker » Sat Sep 26, 2009 3:09 pm
Another awning option and one that was the best solution for me in this common teardrop quest for shelter: Teardrop Awning Solution!
Scott G.
Oasis Maker
Images: 187
Postby doug hodder » Sat Sep 26, 2009 5:15 pm
I like that awning Scott! Looks great and gives you all sorts of head room.
I used the 777300 studs from Endo's post. Half as many holes to put in the tear roof, sealed them underneath with 3M 5200. Doug
Postby hunter535 » Sat Sep 26, 2009 6:26 pm
Oasis Maker wrote:Another awning option and one that was the best solution for me in this common teardrop quest for shelter: Teardrop Awning Solution!
Scott G.
That is a cool awning.
I especially like the shorthair pointer. I lost mine in the spring. They are great dogs. Thanks for the post. :thumbsup:
hunter535
Images: 47
