I’m starting my build from a HF trailer, Model 90153, which has three-leaf springs. The operating instructions say that the maximum weight capacity of the trailer is 1,350 pounds, but my intended, all-up load will be less than half of that (i.e., under 600 pounds). When I put a spring assembly on the floor upside down so that it makes an arch and I then stand on it, the spring barely deflects and barely slides horizontally.
This was my test setup: I butted the eye-end of the spring against one of the 4”x4” legs of my 500# plus pounds of workbench, so I knew that end of the spring wouldn’t move. Then I stood on the spring and measured the deflection of the arch and the movement of the slipper end with a 1” travel, dial indicator. I repeated the tests and averaged the results.
Admittedly, at 135 pounds (fully dressed), I’m a bit light. But 135 pounds is about 25% of the trailer’s intended working load, and I couldn’t flex the OEM spring assembly except negligibly, suggesting a very rough-riding trailer.
So, I pulled one leaf and ran the same test, and I got the following results:
Vertical Deflection: 0.085”
Horizontal movement: 0.070”
That’s a bit of movement, but still not a lot. Not even 3/32”.
Then I ran the same test with a set of leaf springs that were a part of a VATCO trailer kit I bought 25 years ago (and never assembled) whose weight capacity (according to the instructions which I still did have) is 1,000 pounds. I got these results:
Vertical deflection: 0.265”
Horizontal Movement: 0.335”
(Round those numbers to 1/4” and 3/8” for you tape-measure types). By either method of reporting, that’s a lot of movement. In fact, I’m wondering if it’s too much movement.
Both springs have a single eye and a slipper end. But the HF springs are 20.5” long as measured from the center of the eye to the center of the slipper foot. The VATCO are longer, measuring 30” center to center, which would account for some differences in behavior. I.e., the longer the spring, the easier it should be for me to deflect a spring having the same thickness as a shorter spring. (Both have leaves that are 5/16th thick.) But besides length, there is also another difference. The HF springs are 2” wide. The VATCO springs are 1 ¾” wide.
My question is this: Am I looking at a Goldilocks situation in which the HF springs (even with one leaf removed) are too stiff, and the VATCO springs are too flexible? Do I need to buy another set of springs?
I see that Eastern Marine sells single-eye, 20” spring sets rated for 650 pounds. The expense would be reasonable: $19.10 per spring. Or, should I build my frame in such a way that I could install either of the spring sets I already have and choose whichever seems to work best? And if both prove unsatisfactory, then buy the Eastern Marine springs?
Frankly, that’s the solution I’m favoring. The spring hangers that HF provides are flimsy junk that need beefing up anyway. (Each hanger is no more than a short section of 2-3/8”x2-3/8”x3/16” channel that is bolted to the trailer frame independently of the other one.) My thought is to fabricate a single-piece spring hanger out of channel that would span the overall distance of any spring I own or might buy. (As for being able to accommodate both 1 ¾” wide and 2” wide springs, that could be handled with shims, which the OEM HF spring hangers already need anyway, due to the sloppiness of the fit between the springs and the hanger, which is more than 1/8”.)
I’ve never owned a trailer, never done any towing. So, I’m appealing to your experience for guidance. How much flex should I be seeing in my springs when I stand on them, when my weight is 25% of the intended working-load of the total trailer?
Thanks in advance, Charlie
