Glue for the sandwich panel
Postby BK One » Thu Oct 01, 2009 8:15 pm
Looking for some opinions. I'm about ready to glue my skins to my 1x framing. I've got Titebond and PL adhesive. Any preference? I thought the PL would be better. Do we have to worry about any fumes emitted after it's cured? We are in an small space.
BK One
Images: 14
Postby Miriam C. » Thu Oct 01, 2009 8:23 pm
My personal preference is TightbondIII. The PL swells and pushes the surfaces away. Still a good hold so your choice! :thumbsup:
Postby Juneaudave » Thu Oct 01, 2009 8:28 pm
Either will work assuming you can get it assembeled and clamped within the open time. Titebond has an open time of about 5 minutes...most PL about 20. I would check those numbers.
Juneaudave
Images: 380
Postby WesGrimes » Thu Oct 01, 2009 8:30 pm
I am using very large quantities of liquid nail. I don't know how well it works, but after working with the fumes for a few minutes you stop caring :?
WesGrimes
Images: 31
Postby asianflava » Thu Oct 01, 2009 10:53 pm
I used epoxy thickened with microfibers.
asianflava
Postby clarkbre » Thu Oct 01, 2009 10:57 pm
I vote for Tightbond III. I used it on the box for my trailer. It dries very strong and doesn't expand at all.
Brendan
Everett, WA
clarkbre
Postby stomperxj » Thu Oct 01, 2009 11:54 pm
Titebond III is the only choice... works awesome
stomperxj
Postby Carter » Fri Oct 02, 2009 4:34 am
I called Dow a few years ago and they recommended Liquid nails for the pink rigid foam to ply. I'd probably use that and Tightbond on the wood to wood surfaces. The Liquid Nails is not expensive in gallon cans.
Jim
I need a new Avatar. I'd put my dog up there but she doesn't look much like me. She's the skinny one.
Carter
Images: 32
How strong is YOUR glue?
Postby Cody Pendant » Fri Oct 02, 2009 5:27 am
Here is a scientific answer for you.
It is an introductory video. They have a free trial period, and you can read the articles in question.
It from a year or two ago or so.
I highly recommend you read them and make a informed decision. July issue of Fine Woodworking Mag. #192. Quite interesting. You might be surprised what they found was the strongest! :o
http://www.finewoodworking.com/Material ... x?id=28853
and the companion article.
http://www.finewoodworking.com/Material ... x?id=28897
Old cowboy proverb: Your wife�s heart is like a campfire. If you don't tend to it regularly, it will go cold.
Cody Pendant
Re: How strong is YOUR glue?
Postby Steve_Cox » Fri Oct 02, 2009 5:56 am
Cody Pendant wrote:Here is a scientific answer for you.
Cody,
Welcome to the forum...... Please don't make me watch the video and search for the results..... just tell us......... :lol:
Steve_Cox
Images: 196
Postby S. Heisley » Fri Oct 02, 2009 10:10 am
TitebondIII :thumbsup:
It really is stronger than wood!
Postby Mauleskinner » Fri Oct 02, 2009 10:26 am
It's also interesting that their "scientific" results are somewhat skewed because they didn't follow the instructions on the package... :? :?
Mauleskinner
Postby BK One » Fri Oct 02, 2009 10:34 am
Thanks to all. I got some PL for my roof and started wondering if it would be better for the sides. I'll probably stick with the Titebond. I know what it does and am used to working with wood glue.
BK One
Images: 14
Postby S. Heisley » Fri Oct 02, 2009 10:43 am
PL is a good glue. I use/used PL wherever I had epoxy on the wood because I know that works with epoxy. But, I'm not a woodworker and don't know if Titebond would work with epoxy or not. Titebond does work great with raw wood.
Postby aggie79 » Fri Oct 02, 2009 1:40 pm
Where I had good, close tolerance mating surfaces and could apply glue and clamp quickly, I used TB III (for example, in the sandwich construction of my floor and sidewalls).
Where there were less close tolerances and I needed some extended working time, I used PL glue (for example, bending and fastening plywood to roof spars.)
Users browsing this forum: Google [Bot] and 10 guests
