Rim size
Rim size
Postby toolbox » Wed Oct 19, 2005 12:17 am
I am considering building a 5*9 tear? What would be a better rim size 14" or 15"? Also how about the width of the rim?
Any thoughts?
Dave
toolbox
Postby doug hodder » Wed Oct 19, 2005 12:37 am
Dave....whadda want for fenders??? and how heavy a tear do you expect to build?? I took my fenders to Big 0 and told them to give me a tire and wheel combo to fill the fender so it looks good....but I did pick the wheels...the Nascar type black spoker...just what I wanted.... doug
Postby madjack » Wed Oct 19, 2005 12:39 am
...too echo Doug(kinda) wottchawant...it's your trailer do what ya wanna do with it...there is no "standard"
Postby toolbox » Wed Oct 19, 2005 12:42 am
Steel fenders.
That brings up another question - are there any regular steel fenders with sharp 90 degree bend so as to fit flush with the tear?
I have yet to find any that are not rounded over on both outside edges.
Dave
toolbox
Postby doug hodder » Wed Oct 19, 2005 12:49 am
Dave...I don't think you will find a formed steel fender with an absolutely Hard 90 degree break on the inside flange..there is going to be some sort of radius.....if that is what you are looking for....if you want to soften that edge....get some fender welting and put it in....if that is what you get...trim the outer edges both front and bottom with a radius...seperates you from all the other formed fenders....just a thought....Doug
Postby toolbox » Wed Oct 19, 2005 12:54 am
Doug-
Please explain - what is "trimming the outer edge of the fender"?
Dave
toolbox
Postby bledsoe3 » Wed Oct 19, 2005 4:51 am
Whatever size wheel you use, make sure your wheel and tire combo clear your side walls.
bledsoe3
Images: 112
Postby SteveH » Wed Oct 19, 2005 6:55 am
About wheel width, don't go too wide. My wheels are 15 X 7" with 205 X 75 tires and they ride too rough because the wheels are too wide for the tires. Whatever tire size you choose, make shure the wheel width is no wider than the tread of the tire. General rule is the wider the wheel reference the tire, the better the vehicle will handle curves and turns and such, but at the expense of ride.
SteveH
SteveH
Images: 42
Postby shil » Wed Oct 19, 2005 9:41 am
I found steel fenders with a 90 degree lip on the inside and a nice radius on the outside at Princess Auto (a Canadian chain). They had skids of 'em. $10 each.
I had a couple of 15" tires kicking around and bought rims to fit.
shil
Postby TRAIL-OF-TEARS » Wed Oct 19, 2005 11:29 am
toolbox.
Fulton Wesbar has fenders that have a 90 deg. edge on one side and a nice rounded edge on the other.
http://www.wesbar.com/model.php?group=1 ... &model=256
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby Normspeed » Wed Oct 19, 2005 11:45 am
Some of the vintage pickup truck rear fenders are made to fit on a flat-sided surface. You'd still want to put some fender welt in there though. I think Road Trip knows of some.
Normspeed
Postby angib » Wed Oct 19, 2005 11:54 am
The Goodyear RV tire guide lists appropriate rim widths for each trailer tire size.
Andrew
PS Didn't write 'tyre' once. Oh, dammit, now I have!
angib
5000 Club
5000 Club
Images: 231
Postby doug hodder » Wed Oct 19, 2005 8:31 pm
toolbox wrote:Doug-
Dave
Maybe a poor choice of words...radius both the front and back outside edge of the fender at the bottom...everyone else has them square....from the factory....a radius might just dress it up a bit....Doug
