5 x 10 trailer
5 x 10 trailer
Postby Philip72 » Wed Oct 19, 2005 3:04 pm
Does anyone know anything about purchasing a frame for a 5 x10 trailer?
Philip72
Postby mikeschn » Wed Oct 19, 2005 3:18 pm
Hi Philip,
Welcome to the forum... I'm not completely understanding your question... do you want to have a frame fabricated or do you want to buy something like the HF trailer....
Fabricating a trailer... check out my thoughts here...
http://www.mikenchell.com/weekender/chassis.html
To buy a red trailer, check out the Red trailers...
http://www.redtrailers.com/TrailersFolding.asp
To get to 5x10 which is what I think your question was, you are going to have to fabricate...
P.S. What's stopping you from using a design that lets you build a 5x10 trailer on a 5x8 frame?
P.S.S. Most cub/modernistic designs use a reduced size frame...
5 x 10 Trailer
Postby Philip72 » Wed Oct 19, 2005 3:23 pm
Thanks Mike. I'm going to chew on your info for awhile.
I didn't know you could build a 5 x 10 trailer on a 5 x 8 frame. I'm not much for building.........I'm the marketer! Got an acqaintance that's building it.
Philip72
Postby mikeschn » Wed Oct 19, 2005 4:02 pm
Check out Finn's design to see how you can roughly build a 5x10 on a 5x8 trailer...
http://tnttt.com/viewtopic.php?t=5422
P.S. Besure to download Cortona and spin the wrl file around!!!
Postby Chuck Craven » Wed Oct 19, 2005 5:15 pm
Hi Philip72.
If you have a Tractor Supply they handle a 5 X 10 no floor trailer by Cary ON. It is a special order to get one that size. They only stock the 4 X 8. I do believe that Cary On trailers have a plant in Texas. :D
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Wood trailer frame
Postby Guy » Wed Oct 19, 2005 5:19 pm
Dear Mike,
Here is a wood torsion box trailer frame that could be the completed extension of your idea for a wood frame using wood beams. The top and bottom of the torsion box would handle easily handle the horizontal forces.
These pics are from an article on West Systems website.http://www.epoxyworks.com/22/staudacher.html
Regards,
Guy
Guy
Images: 44
Postby Chuck Craven » Wed Oct 19, 2005 9:30 pm
Here is there web sight! www.carry-ontrailer.com/ The no floor trailer is not listed but you can call them. The trailer is rated for 2000 lbs. If you order it from carry on they will set the axel any distance from the back of the trailer that you want. :thumbsup:
Chuck
Chuck Craven
Images: 62
