I'll never understand why they put a brown/black fuse box on a white cabinet.
Bill, since I'm originally from Atlanta, I will allow you to give advice on improving the appearance, even though you are a male.wlooper89 wrote:Hi all,
There have been some very good tips about improving the appearance of the panel. Being a male I will not try to add to those.I have an earlier model LG and got it without the electrical option. The panel in your photos is not the same unit nor in the same place that I added, but similar in color and shape. In my trailer that is the converter. Under the lid are some fuses and one or more circuit breakers, and underneath that are the converter workings. The converter will recharge the trailer battery if AC is plugged in, so it is handy to have. This is just a description of what I think the panel may be for, in addition to a fuse panel. Perhaps my guess is wrong and in any case I am sure others on the forum are better qualified to give suggestions about improving the looks of the unit.
Bill
Now, that proves that I was completely wrong, when I said that a man must have installed that ugly fuse box. Because, I was thinking of a curtain, myself. I was thinking a tension rod going from one side wall to the other, with a short curtain hanging there. But, I like your velcro idea, better! It would hide the entire panel, underneath the cabinets.wlooper89 wrote:
I appreciate your tongue-in-cheek response and hope you get the fuse panel all fixed to your liking. I am wondering if a small curtain might work. I put curtains over the trailer doors with the help of my mother-in-law, who used to own a custom drapery shop. She sewed a strip of Velcro along the top of each curtain that sticks to the fabric on the LG walls. That makes the curtains easy to remove during the day. You probably do not need to access the fuse panel very often so a curtain type thing covering the forward end of the box or even both sides might be fine.
Bill
Shadow Catcher wrote:A number of companies now make spray paint to cover plastic, paint is cheap and if all you have are fuses you do not need to be concerned. the fuse box used in automobiles are some times sealed and water tight and I have not seen one that was ventilated, if they are hot there is a serious problem.
