2001 F150
2001 F150
Postby CASHCOW » Sat Oct 10, 2009 3:22 pm
My heater is not putting out heat no my 01 F150 We checked the blend door motor and that is not the problem. One hose is hot the other is not. :fb where do i look next
Serro Scotty Hilander http://txmc08.blogspot.com/
CASHCOW
Postby Juneaudave » Sat Oct 10, 2009 3:45 pm
Not good...be sure to check the antifreeze level in the radiator (not the overflow tank). You really want to eliminate the obvious first...Dave
Juneaudave
Images: 380
Re: 2001 F150
Postby Steve_Cox » Sat Oct 10, 2009 5:54 pm
Mike and Brenda wrote:My heater is not putting out heat no my 01 F150 We checked the blend door motor and that is not the problem. One hose is hot the other is not. :fb where do i look next
Might be a vacuum operated heater valve problem. Link to a diagram
Steve_Cox
Images: 196
Postby Jiminsav » Sat Oct 10, 2009 6:31 pm
sounds like a blockage..or someone took the hoses loose from the heater core and bypassed it because of a leak..
Jim in Savannah
Jiminsav
Images: 40
Postby Woodyperk6 » Sun Oct 11, 2009 7:48 am
Mike, did you get your heater fixed? You might need it in Amarillo this winter.
Woody & Tammy
One day closer.
Woodyperk6
Images: 5
Postby CASHCOW » Sun Oct 11, 2009 8:18 pm
don't know that i did but got i to work ty for you help
mike
CASHCOW
