tears4mama wrote:I too am wondering how to insure that the wall strength is good for bunks. I have an 8yo and 6yo. They have impressed on me that they should sleep in the camper too!
angib wrote:For CNC cutting of plywood, you may have success asking companies that normally use their water-jet cutter on granite or marble, like for kitchen work-tops (US: counter-tops?).
I know the idea of water on bare ply will scare some folks, but I've used MDF that's been cut by water-jet with no trouble and you know what a sponge MDF is.
Andrew
mikeschn wrote:My thoughts are to experiment with gas springs again, only this time, not so close to the hinge.
Once I have the gas springs lifting the top comfortably, I'll design the interior around them.
It's not an easy task, with so many unknowns.
Scott, when do you start your build?
I think I start mine next spring...
I found a place for the furnace. Can't find a place for the AC though. I think the hot water heater will go under the bed. I might have to move the axle rearward, if I get too much stuff under the bed. Speaking of which, I have a good question about potable water... I'll start a new thread for that though.
mikeschn wrote:Scott,
A couple good ideas for sure.
Can you tell me more about the foam laminate roof you are considering?
Are you going to have any spars in it? Are you going to put the fiberglass and resin right on the foam? And you're talking EPS, right, or are you talking R-tech?
Are you going to use foam for the sides of the hatch too?
And you're planning on painting the whole thing?
kennyrayandersen wrote:OK,
here goes. I think Lou means the part that attaches the seatbelt to the lower edge of the outer wall.
The first one is a side view hinge toward the right.
View looking aft
roller detail
Crank detail
