Computer Question
Computer Question
Postby Classic Finn » Sun Oct 11, 2009 3:40 am
Hello everyone.
We have a question for you concerning our computer. Its been very slow.
What can I do to speed it it up more. Ive basically gone and cleaned it from all possible extra temp files and so on. Is there a free program that can clean it up ? Or what more can be done.
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby PaulC » Sun Oct 11, 2009 5:14 am
Heikki, have you run defrag lately?
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby digimark » Sun Oct 11, 2009 6:31 am
A computer always runs at the speed it did when you bought it. The things that change over time are:
1. Your perception of how fast it should go. (Based on seeing newer machines run faster, what friends have, new software that comes along and really needs better hardware to operate nimbly, and the experience of using that software over time.) I usually tell people, "the computer you bought three years ago is just as fast today as it was then, but your expectations on how fast it feels, can change." Not much you can do about that except adapt or buy new...
2. What programs the system is running -- the operating system changes over time with new patches, new software that you install, all the little programs that run in the background (look at the list of processes in the Task Manager on WinXP, for instance), etc. This group also includes malicious software you didn't ask for like virii, spyware, stoopid little toolbars/free software packs that come with the software you buy/download, software systems like MS Office or the anti-virus packages like Symantec/Norton that have fifteen little things running "to help you" (they don't), as well as the dumpware that comes with the machine. etc. You can make a dramatic difference by disabling or de-installing a lot of this junk. What the computer really needs to work properly is a small subset of what is usually running on the average PC.
3. Check to make sure you have installed all the available latest updates from the vendors for the OS and software packages -- these will include bug fixes and enhancements that may make a speed difference.
4. Defragmenting the disk can help, but the newer the OS, the less the need for this, as they handle this chore in the background automatically. But make sure you have adequate free space on your hard drive -- if you are running 99% full all the time, the system will slow down as it has to constantly move things around to make room for whatever it's doing at the moment.
5. If you run a lot of programs simultaneously and switch amongst them, more system memory (RAM) will help. And the system will use the extra memory you're not using as a disk cache for speeding up access to materials on the hard drive.
Of course this presumes there isn't really a real hardware failure. But once you've gone through all this, if the computer's mainboard can support it, you could look into replacing the processor, possibly with a dual or more processor). Most of the time though, depending on how old your current computer is, a newer computer with a variety of improvements over the current one is usually less expensive than trying to upgrade the old one.
Hope this helps.
-- Gary Goldberg/Chesapeake Beach, MD/KA3ZYW
-- http://www.digimark.net/og/
digimark
Images: 40
Postby rxc463 » Sun Oct 11, 2009 6:38 am
I have found that running a registry cleaner on occasion makes quite a difference in performance. Follow instructions carefully and do a backup before making any manual or software initiated changes to the registry.
Nonags freeware has several good free registry cleaners in their power tools section.
Russ
Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason.
rxc463
Images: 20
Postby WesGrimes » Sun Oct 11, 2009 7:54 am
Hold the windows key and hit 'r'
The Run dialog box will open.
Type 'msconfig' click ok to open the System Configuration utility.
Click on the 'Services' tab.
Put a check in the checkbox that says "Hide all Microsoft Services" (it is near the bottom of the window)
Click the 'Disable All' button. (You may want to selectively enable certain services, such as you antivirus)
Click on the 'Startup' tab.
Click the 'OK' button.
Reboot
Enjoy the new found speed.
You should probably defrag a couple of times as well. I find that once is never enough.
Wes Grimes
Microsoft Certified System Engineer
WesGrimes
Images: 31
Postby Classic Finn » Sun Oct 11, 2009 8:06 am
PaulC wrote:Heikki, have you run defrag lately?
Cheers
Paul :thumbsup:
Hello Paul and greetings from the far nort ;)
No I havent run defrag. I,ll do that next. :oops:
Thank You Paul :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Sun Oct 11, 2009 8:07 am
WesGrimes wrote:Hold the windows key and hit 'r'
Reboot
Wes Grimes
Thank You Wes I,ll follow up on your advice :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Sun Oct 11, 2009 8:08 am
Ohh since Im no expert at this.. :oops: When I defrag I wont lose any of my data correct? Ive got all info backed up now as well. :thinking: :roll:
Thanks Everyone
Classic Finn
Images: 146
Postby WesGrimes » Sun Oct 11, 2009 8:15 am
Classic Finn wrote:Ohh since Im no expert at this.. :oops: When I defrag I wont lose any of my data correct? Ive got all info backed up now as well. :thinking: :roll:
Thanks Everyone
No, defraging just rearranges where the data is stored on the hard drive.
It speeds it up because the hard drive armature does not have to seek all over the disk platter to open a file because the contents of the file will be inline after the defrag.
Short answer: nope, no data loss.
WesGrimes
Images: 31
Postby Classic Finn » Sun Oct 11, 2009 8:54 am
Thanks Everyone
Thank You kindly Wes. I also did the registry check and it repaired a whole lot there. Ok I,ll defrag now.
Back in a bit :thumbsup: :D
Classic Finn
Images: 146
Postby Classic Finn » Sun Oct 11, 2009 9:59 am
rxc463 wrote:I have found that running a registry cleaner on occasion makes quite a difference in performance. Follow instructions carefully and do a backup before making any manual or software initiated changes to the registry.
Well Russ that seemed to do the trick. Thank You :thumbsup: :D :)
Classic Finn
Images: 146
Postby Classic Finn » Sun Oct 11, 2009 10:01 am
Thanks Everyone
Defrag run. I need to install a set of seat belts on the computer now. :lol: :D Lot faster for sure. :thumbsup:
Classic Finn
Images: 146
Com.Q
Postby john curtis » Sun Oct 11, 2009 10:09 am
Have you tried running Windows Clean Up 4.0 .Very small program for free.Look in Google.I run this program befor I shut down daily.You will be amazed at how much junk it gets rid of.
John
john curtis
Images: 141
Re: Com.Q
Postby Classic Finn » Sun Oct 11, 2009 10:31 am
john curtis wrote:Have you tried running Windows Clean Up 4.0 .Very small program for free.Look in Google.I run this program befor I shut down daily.You will be amazed at how much junk it gets rid of.
John
Hi John
Must admit that I have not. But I,ll check into it. Thanks for the tip. :thumbsup:
Classic Finn :)
Classic Finn
Images: 146
Postby Arne » Sun Oct 11, 2009 10:33 am
Wes Grimes: is there a good registry cleaner out there, or in windows xp?
I tried a free one a couple of years ago and I had to take my computer to get it fixed after the cleaner screwed things up. The repair shop told me never to try to clean the registry in windows xp.
I've read a lot of comments like this:
Don’t…I’ve “experimented” with a variety of registry cleaners including ccleaner and though in most cases any damage could be reversed, in my last “experiment” it failed miserably and windows was totally trashed. Well not totally I could still boot but it was full of errors that only got worse as I attempted fixes. Ended up buying a new drive, restoring from my original restore CD and then installing only minimal programs. I kept the old drive to access data as I needed it. I must say things run fast now. Now that is a good registry cleaner ;-)
CF, all computers slow down as we add stuff to them. They just have to handle more crap we stick on it......
I defrag about once a week... the longer you let it go, the more work the computer has to do to get things back together....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
