I know it can be done- I would like some feedback on how.
I would like to make a tear generally the same design as the ultralight, only with a frame. If I use an HF frame I believe that I will need to shorten it about 14â€
RogHodge wrote:Thank you sir- that would be easier- howoever the front rails are slightly tweeked- the bottom portion is ‘ripped’ a bit- like if it were folded wrong. My thought is to lose the messed up portion and have a truer frame without taking it to a frame straightening shop.
schaney wrote:They are also about half what Red Trailer charges for a straight tongue frame, wouldn't be surprise if their kits aren't also from Long Chin.
